Scrape off what you can, go to Walmart or home Depot and buy yourself an angle die grinder and some cookie pads. You'll need to rent/borrow an air compressor, but thats the best/easiest way to remove that stuff
I took my valve covers off because there was a horrible leak. After taking off and putting one back on, I noticed the lower bolts were too short to tighten because of the 3/16 inch gasket installed. The hanes book sounds like the gasket is optional. Should I remove the gasket and just use sealer?
having replaced mine on my 85 a few times, i would spend the extra cash and use felpro permaseal gaskets.. these are rubber based with a metal middle piece. i must admit that removing and installing these things is a pita. there is a tech tip on this for the 85. i removed the cover to the windshield wiper motor assembly for clearance on one side and I think i had to play with the brake booster vacuum line on the other side. you can purchase slightly longer bolts at a decent hardware store. i cleaned the factory orange sealant stuff the best i could and wiped down with solvent. the seal has been good for a few years. make sure you torque down evenly and according to spec
Opinions and experience welcome.
Note: 84 crossfire injection
I've never done and 84 but......If you have short bolt issues but can get away with using just RTV. I recommend using a product call the "Right Suff" I've never had a leak with using this....it sticks to just about anything that isn't coated in oil. Clean the covers as well as you can first then lay down a good tall bead of gasket maker and don't over tighten the valve cover bolts.
The fel pro rubber gaskets are the best had them on and off a couple of times. Didn' have no sealer mess. Auto zone sells a heavey spreader chrome. They spread the pressure on the cover. I have this on my 86 and no leaks.
