Water
Old May 16, 2009 | 12:53 PM
joe3906's Avatar
joe3906
Default Water
Took the vette out for a spirited drive, and naturally everyone wants to challenge you; so I decided to just get away. Anyway, the car is smoking from under the hood, but the gauges all indicate within normal operating temperature. When I open the hood there's water everywhere. What could have been the cause of this? I did drive the car hard, but it's an LT4, it's made to be a mover. I recently had a performance cam ( 503) installed, and while the engine was open, the mechanic thought it was best to chnge the waterpump. I still have the old wp, but I'm just grasping at straws here. Please advise, corvette gurus.
Thanks,
Joe B.
Old May 16, 2009 | 01:22 PM
MK 82's Avatar
MK 82
First thing I would check would be all of the hoses.
Old May 16, 2009 | 02:28 PM
joe3906's Avatar
joe3906
Thanks, I did check, but should I check with the engine racing?
Old May 16, 2009 | 02:59 PM
floridamale's Avatar
floridamale
At least running and up to temp
Old May 16, 2009 | 07:18 PM
GKK's Avatar
GKK
Yes, check the cooling system when under pressure so, you can see where the coolant is coming out from. Also, do a pressure check on the cooling system.
Old May 16, 2009 | 07:53 PM
danamals16's Avatar
danamals16
yea run it try to duplicate what u did when u were racing to see if and what is leaking
Old May 16, 2009 | 09:40 PM
joe3906's Avatar
joe3906
Thanks folks, I will do as you recommend. I'll check the sysem with a pressure tester Monday. I really appreciate the help.
Thanks,
Joe B.
Old May 18, 2009 | 04:58 PM
joe3906's Avatar
joe3906
Bingo; pin-hole in the small hose that runs from the passenger side closest to the engine and runs along the fuel rails. Fixed. That's again for the help.
To Water
