My misery
Old Jun 14, 2010 | 10:53 AM
  #41
timmy 93's Avatar
timmy 93
Originally Posted by demon seed
just spent half hour typing this out and comp.froze so here we go again- cleaned all connections i could find and still no start!And for MK 42 it all started with a little hesetation off the line and a knocking like it was out of time.It would spit and sputter untill i took my foot off the throttle,then it would take off like normal.took it in and got a vacume test new plugs and wires,an injection air intake purge fuel filter,two knock sensors.nothing changed no codes dealership was speechless didnt know where to go from this point.So 2 winters ago i had my opti changed (cause it craped out)to a msd and a msd coil ,and new water pump.car ran fine for a week then i put a chip in ....ran fine for 2 days then i noticed it's taking longer to start so out comes the chip,car was taking 10-15 min. to start,but once it started it drove and after shutting off it started right up.just after complete cooldown is when it happens.i had another ecm from before .wasnt the problem so i had a spare.tried both no change.here's what ive put in - 2knock sensors................................$ 114.78 map sensor.................................. ....$23.37 map sensor pig tail ........................ $21.54 2rear u-joints replaced......................$56.00. labour.................................. ......... $436.00 ecm..................................... ..........$344.51 msd dist.................................... .....$629.00 msd coil.................................... .......$59.83 msd rotor .................,,,,,,,,,,,,,,,,,,,,,,$ 32.60 my msd dist was missing rotor!!!! injection air intake purge.................$129.95 fuel filter.................................. .......$36.80 trans.flush............................. ........$157.40 bosch 3injectors(jon's).....................$2 00.54 platinum plugs................................$23 4.00 spark plug wires..............................$136. 00 thermostat.............................. .........$35.70 TB gasket.................................. .......$12.80 harmonic ballancer...........................$285 .95 water pump.................................... .$360.94 labour for installs and tests....... $616.00 $399.75...$679.81..$240.00....$456.25
I see the msd dist. was missing the rotor cap.Was the dist used? A new unit would not be missing a rotor. Tim
Old Jun 15, 2010 | 01:19 AM
  #42
demon seed's Avatar
demon seed
the msd dist. was brand new,i bought it, gave to mech but ut sat in his garage for 5 monthes before he opened it (winter project) . he kept my car all winter i was in no hurry to get it back in the snow.So i got free storage all winter.for you other guys -i didnt just throw all these parts at it because it wont start ,it all started with a stumble on acceleration.over 2 years of trying to chase down this prob led to all these parts.when 2 dealerships cant figure it out and one private mech. the private mech installed the msd,water pump,coil,plugs,ceramic brake pads plus winter storage and labour for 1400.00 that includes the cost of waterpump,i think i got a hell of a deal. anyway thanks for all your imput and advice. Ill have time this weekend to look at it. Iwould like to know where that guy can find a fuel press.tester for 12.00. cheapest i can find is 59.99.any way im picking one up this week.thanx again everybody
Old Jun 15, 2010 | 06:44 AM
  #43
Moon86's Avatar
Moon86
One thing for sure, you've got to determine whether the problem is on the gas side or the electrical side before you go throwing more parts at it. Was the fuel pressure checked while you were trying to start it or just with the key on? The part about taking longer and longer to start sounds like a fuel problem to me. Hope you find the problem.
Old Jun 15, 2010 | 07:08 AM
  #44
Moon86's Avatar
Moon86
You may be able to sign out a fuel pressure tester at Advance Auto or some place like that. One thing I'm finding out from reading this forum is that the first thing you have to nail down is the fuel pressure.
Old Jun 15, 2010 | 07:27 AM
  #45
Pete K's Avatar
Pete K
If the gas is 1 1/2 years old, drain it and put some fresh stuff.
Old Jun 15, 2010 | 02:02 PM
  #46
Bondami's Avatar
Bondami
From: Southside of Western Norte Americano State of Confusion, ColoFornia
St. Jude '13
Amen!
I just want to add, at this point you need to forget EVERYTHING that has been replaced.. just troubleshoot from square one..all of this "it cant be that it's new" thinking is only confusing the issue.. Start with the basics
Fuel pressure, Spark and move on from there. the simple diagnostic procedure will lead you to the problem. It may very well be something simple and overlooked.
Old Jun 15, 2010 | 05:17 PM
  #47
The Green Rocket's Avatar
The Green Rocket
What he said.
Get a factory service manual, they have the best diagnostic flow charts. Alternatively: find a new mechanic. Not because yours is not capable - sometimes a fresh face will see something missed by others.
I hope you kept all the old parts/sensors etc., because most of them likely have nothing wrong with them.
Thomas
Old Jun 15, 2010 | 09:19 PM
  #48
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
good advice
Old Jun 15, 2010 | 10:23 PM
  #49
demon seed's Avatar
demon seed
i have 3/4 of a tank of fuel.anyone know an easy way to drain. or do i get out the garden hose and mouthwash.
Old Jun 15, 2010 | 11:34 PM
  #50
primalurges's Avatar
primalurges
If you have a fire extinguisher handy, home depot has a drill driven pump that runs about $10. Its not made for gas so you have to be careful with it. I used it to drain 35 gallons from my boat, worked like a charm and did the job in about 10 minutes
Old Jun 16, 2010 | 07:20 AM
  #51
Moon86's Avatar
Moon86
Why not disconnect the fuel line at a convenient point, hose clamp some tubing on and use the fuel pump to drain the tank?
Old Jun 16, 2010 | 07:50 AM
  #52
Pete K's Avatar
Pete K
It has been years since I have done it, but check your service manual. There is a way to run a 12 vold wire to the diagnostic port and run the pump. Once you fiure this out, you can easily do what has been suggested above.
Wouldn't it be something if the fuel is the reason it won't start?
Old Jun 19, 2010 | 02:37 PM
  #53
demon seed's Avatar
demon seed
finnaly got one!! still cant figure out this inserting pics sh-t.
Old Jun 19, 2010 | 03:29 PM
  #54
Weav's Vet's Avatar
Weav's Vet
If you uploaded it to Photobucket just Copy & Paste the "IMG Code" into your post here at CF. You'll ususally find this box on the left of your picture in PB after you enlarge it there..
Old Jun 19, 2010 | 03:51 PM
  #55
demon seed's Avatar
demon seed
ok figured out where copy and past are but i click on them and nothing happens,i tried dragging them too ....nothing ,tried typing in the img code but comes up as a red x on forum?
Old Jun 19, 2010 | 08:55 PM
  #56
demon seed's Avatar
demon seed
Drained fuel and put in fresh...fuel press jumped to 42psi instantly(hallaloooooooya) ..droped down to 40psi after 5 min. stayed at 40psi for half hour! [IMG][URL=http://s789.photobucket.com/a[/IMG] also pulled vacume line off fuel regulator (i think) and didnt smell gas before and during pressure test!! is it supposed to smell ? I see the pic's didnt woork.... ill put them in my garage for viewing.
Old Jun 19, 2010 | 09:42 PM
  #57
KARR's Avatar
KARR
Hey Demon,
I am new to the forum, just bought my Vette 3 weeks ago. I don't have any technical advice to offer. I just wanted to say that I admire your tenacity to get the problem fixed. You have incredible patients and if I were in your shoes, that thing would have been towed to my mechanic on day 2!
I hope you get your Vette running like a champ again soon. You are a better man than me! :-)
John in San Antonio
To My misery
Old Jun 19, 2010 | 11:32 PM
  #58
shamdave's Avatar
shamdave
Mine was a similar problem, check the fuel pressure regulator, i replaced about everything you did and that was the ticket for me, also when all else fails you can try Gordon Kilabrew
I am in Cincinnati If you are close i can PM you a great Corvette guy.
Old Jun 20, 2010 | 12:42 PM
  #59
demon seed's Avatar
demon seed
thinking about getting a fuel press regulator? any way to test the one i have now.
Old Jun 20, 2010 | 01:01 PM
  #60
Keystring's Avatar
Keystring
UPDATE- just finnished installing jons fic injectors .....piece of **** still wont start must be something else I read in this (common problems) thingie that wile trying to start, the engine will stumble like its trying to start when you release the key back to the run poossition. thay said it is a poor or insufficant power supply to ignition. Dose this sound possible , has it happened to anyone else. where would a guy look to inspect these wires. Hell it could just be the ground .
I've had this happen to me once.
My car wouldn't start (85 Trans Am) . I would try starting it and it would just turn over. But when I released the key it would 'sputter'.
So, instead of ripping it apart and replacing things at will, I took out a volt meter and hooked it up to the power wire on the distributor.
With the key in the 'start' position, it showed no voltage. In the 'run' position the 12 volts reappeared.
Turned out I had a bad ignition switch (at the base of the column).
Replaced it and the car started right up.
Just a thought!
