Loose side mirror
Old May 20, 2009 | 03:39 PM
jcs44's Avatar
jcs44
Default Loose side mirror
My left side mirror is loose on my 96. Can someone tell me what holds it on there and how to get to it.
Thanks, jcs44
96 LT4 Roadster
Old May 20, 2009 | 07:11 PM
lilredc4's Avatar
lilredc4
The mirror (glass part) just snaps into connectors in the mirror frame. Once you remove the glass part you can see the bolts holding the frame to the car. If the glass itself is loose there are screws that can be tightened once you remove the mirror. Be very carefully and pull the mirror out with your hands and you will see what i mean.
Old May 20, 2009 | 10:00 PM
exactmetal's Avatar
exactmetal
i have the same problem but was afraid to attempt to remove the glass,,,i saw a cross looking item sold on ecklers for loose glass butt if there are screws maybe they are loose worth a shot ,,im still scared of things that break easy
Old May 20, 2009 | 10:10 PM
SunCr's Avatar
SunCr
You can see at least one of the screws by moving the mirror down and and toward the window.
Old May 20, 2009 | 11:01 PM
Hooked on Vettes's Avatar
Hooked on Vettes
As mentioned, use your fingers and move the mirror glass around until you can put your fingers behind it on two sides. Then pull the mirror straight towards you. The back of the mirror snaps onto the trunion and two pivot studs.The trunion is the cross shaped silver colored object in the picture.
Place a towel on the door so the mirror doesn't scratch the door paint because the heated mirror wires will still be attached to the glass. Let the mirror hang from the wires. In the picture you can see the 3 screws with a red circle around them. Remove them and the motor will pull off. This will give you easy access to the 3 screws that hold the mirror mounting bracket to the mirror housing. The screws usually back out which causes the mirror to shake when the vehicle is moving.
Old May 21, 2009 | 09:34 AM
jmrl98's Avatar
jmrl98
Thanks hooked - a minor project I still have to get to.
Old May 21, 2009 | 10:22 AM
jcs44's Avatar
jcs44
THANKS! I thought I was going to have to pull the door apart on the inside. This looks relatively simple. I assume the mirror comes loose before it breaks.
jcs44
Old May 21, 2009 | 10:43 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Great photo and advice. The trunion in the photo looks like the metal replacement that Ecklers and other sell. Is this correct? Also, can you show us a photo of the back of the mirror illustrating the trunion hold-down fingers? Finally, do you have any advice on how to best line up and snap the mirror back in place?
Old May 21, 2009 | 02:20 PM
Hooked on Vettes
jcs44
Having small hands makes it easier to pull the mirror off of the trunion. If you look closely at the photo of the backside of the mirror you can see the mirror is glued to a plastic backing which also has two plastic studs with threads on them. When you move the mirror around the ratcheting noise you hear are the two studs moving in or out of the motor. To reinstall the mirror line up the two studs and press them into the motor. Pressing further should snap the trunion back on to the back of the mirror.
The other pic. shows the motor removed from the mounting bracket. You can see the 3 phillip head screws that usually back out.
Once the 3 motor mounting screws are removed you can unplug the electrical harness and the mirror and motor can be set aside. I just leave them hanging.
Old May 21, 2009 | 03:43 PM
pmihaltian's Avatar
pmihaltian
Slingshot
GREAT ! Thank you, I have been waiting a long time for someone with your knowledge & photos to show us how to do this. I have had a new trunion for years and have always been leary of just trying to pull the mirror off as others have said to do. Finally, now with your great photos, I think I'm confident enough to give it a try. Thanks again
Old May 21, 2009 | 03:45 PM
exactmetal's Avatar
exactmetal
hooked ,,,,thanx for the great pics and details,,,makes me feel a little more confident that i can finally fix my droopy glass....
Old May 21, 2009 | 07:05 PM
exactmetal's Avatar
exactmetal
well i found my problem,,,,one of the mirror studs is missing,,any ideas on where to pick one up,,,or has any one rigged one,,let me know please
Old May 21, 2009 | 11:26 PM
"J"'s Avatar
"J"
From: Bardstown ( Bourbon capitol of the world ) KY ( The Bluegrass state )
I'm glad you made this post Mine started shaking around tonight on my way home. Thanks for the post and Thank you Hooked on Vettes for the nice description
Now I guess all there is to do is get up and fix it
Old Jun 1, 2009 | 10:00 AM
jcs44's Avatar
jcs44
Well, the mirror comes out of there pretty easily, but I guess I asked the wrong question. It's my left side mirror bracket/housing that is loose where it is attached to the door, so I guess the inside door panel has to come off to get at the screws or bolts. What's the procedure to get the door panel off?
Thanks, JCS44
Old Jun 1, 2009 | 10:55 AM
GKK's Avatar
GKK
Remove all the screws along the perimeter of the door panel, inside the grab handle and there is one behind the light above the door release handle. From the top edge, just pop off the plastic door light cover with a flat blade screwdriver to access it. Using an L shaped tool, gently pry up on the front edge of the door lock cover and lift up to remove it. This is for the earlier 91-94 door panels but the 96 should be similar.
Gently pry up on the window switch panel and disconnect the wire harness for the power window and mirror. Also, disconnect the wire harness for the light above the door handle and lower door sill.
The mirror housing is held on by two 10mm nuts easily accessed through the door panel frame.
Old Jun 1, 2009 | 12:45 PM
jcs44's Avatar
jcs44
Thanks GKK!
Old Jun 1, 2009 | 01:00 PM
Jimbo3087's Avatar
Jimbo3087
Is that the same for an 84? I have the electric mirrors as well..
To Loose side mirror
Old Jun 9, 2012 | 10:30 PM
ProjectC4's Avatar
ProjectC4
What about the rubber covers on the threaded rods? I was taking one of mine apart today & the cover ripped. I have looked at all the mirror threads & the rubber covers are not mentioned.
Old Jun 10, 2012 | 11:55 PM
Cliff Harris's Avatar
Cliff Harris
I have the rubber covers on my '86. I had to rip one to see what was going on because the stud came out of the motor and I couldn't figure out how to get it back in. I don't think that's a problem because the later ones don't have the covers.
Old Jun 11, 2012 | 09:33 AM
caddyboy84's Avatar
caddyboy84
Great that you could post those pics, very helpful to alot of people A picture is worth a thousand words .
