Loose side mirror
Old Aug 15, 2012 | 03:42 PM
j-wireman's Avatar
j-wireman
Originally Posted by caddyboy84
Great that you could post those pics, very helpful to alot of people A picture is worth a thousand words .
Wish there were more in-depth how-to's WITH photos.
For instance, how about doing one for taking the door panels off to replace the door glass seals. Or, how about one showing how to take the console and everything apart to change the carpet or replace the stereo.
Yes, I have a Factory Service Manual (FSM). But, it leaves a lot to be desired, description- and picture-wise. Some of the illustrations are just plain terrible. So, photographs are really needed to know where to place a tool, what to pry, what is on the other side of this?, what's holding that?, etc.
As caddyboy84 said, a picture really is worth a thousand words.
Thanks, Hooked On Vettes.
Old May 19, 2021 | 07:27 PM
shafe9900's Avatar
shafe9900
Advanced<br><img src="/forums/images/ranks/100-500.gif" border="0">
2023 Corvette of the Year Finalist - Unmodified
2022 C4 of the Year Winner - Unmodified
Originally Posted by Hooked on Vettes
As mentioned, use your fingers and move the mirror glass around until you can put your fingers behind it on two sides. Then pull the mirror straight towards you. The back of the mirror snaps onto the trunion and two pivot studs.The trunion is the cross shaped silver colored object in the picture.
Place a towel on the door so the mirror doesn't scratch the door paint because the heated mirror wires will still be attached to the glass. Let the mirror hang from the wires. In the picture you can see the 3 screws with a red circle around them. Remove them and the motor will pull off. This will give you easy access to the 3 screws that hold the mirror mounting bracket to the mirror housing. The screws usually back out which causes the mirror to shake when the vehicle is moving.
Thanks for the tip, took 10 minutes and solved my problem!
Old Jul 10, 2022 | 07:34 PM
Scott Rasmussen's Avatar
Scott Rasmussen
Default thanks for the piano info
thanks for the pictures and info, i fixed the loose passenger side mirror on my 93. it was the screws in the back that were loose. tightened them up and no more loose mirror!
