IAT snesor... need help!
I recently installed a mini ram on my 85vette, and a got a mail order tune from Fast Chips after the install. On the old TPI plenum the IAT sensor mounted on the bottom rear of the plenum, but the mini ram doesn't have a mounting port for the IAT. So I relocated it to the air filter housing just before it coneects to the MAF. Did I mount it in the wrong location? If so... is there another location it should be mounted?
On any low voltage sensor circuit..it's not something I'd suggest...solder the wires and heat shrink tubing
I agree, your method of connecting a vital engine sensor looks to be u-haul temprary trailer connectors (scotchlok) or (schlok-lock). If you go to an auto parts store, get a kit of crimpers and connectors. Soldering engine harness connectors is no good. The wires are soldered, and the solder wicks up the wires, and creates "stiff" areas in the wire that aren't flexible. These inflexible joints are subject to vibration and manipulation, weather, heat, and other things that eventually work harden the solder, and it breaks off, leaving u stranded. Crimp crimp crimp. only way to go. then once you crimp the wire, pull on it to make sure it has a death grip on the wire.
http://members.shaw.ca/corvette86/Code%2023.pdf
