L98 Redline
Old May 29, 2009 | 01:58 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Default L98 Redline
My car has been on blocks for awhile and I've forgotten....What's the redline for L98's? especially 1989 or thereabouts.
A web search showed the LT1 as being 5700rpm -- 700 higher than the L98! The only other site I found showed a 1991 L98 redlining @ 5200rpms. (To be clear, I'm NOT talking about peak power rpms!)
D@MN!... I didn't remember it being THAT low! Maybe I'm not being so conservative in my goals to build a 5k-5.5k rpm setup -- reusing my 55k production short block.
Is the heavy pistons the problem?
gp
Old May 29, 2009 | 03:45 AM
slickfx3's Avatar
slickfx3
gp
my tach starts to show yellow at around 5k
Old May 29, 2009 | 03:59 AM
cv67's Avatar
cv67
St. Jude Donor '05
Heavy pistons, thinner rods starting in 89. It will live though.
Old May 29, 2009 | 04:08 AM
ultraviolet70's Avatar
ultraviolet70
Aw Gregg, just get the 383 short block and don't worry about the L98 redline.
Just kidding.
Got your e-mail, the runners are looking good
Did you do the exterior polish on them?
Old May 29, 2009 | 04:14 AM
cv67's Avatar
cv67
St. Jude Donor '05
If he gets the 383 then he will have to change intakes .
Hmm, decisions decisions, HSR or TPI? Mon Wed or Fri? Even or Odd? Go to Kmart with Iris at 10?
Old May 29, 2009 | 04:17 AM
ultraviolet70
Yeah, but then he'll have 2 engines, 2 intakes and he can use one on each but which on which?
Old May 29, 2009 | 08:29 AM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Old May 29, 2009 | 08:41 AM
neat's Avatar
neat
I took the stock bottom end to 6500 quite a few times after I changed heads/cam/intake. I finally broke a piston, but that may have been nitrous related as opposed to RPM related.
Old May 29, 2009 | 09:19 AM
Aardwolf's Avatar
Aardwolf
Had mine to 6,000 numerous times while dialing in the governor springs/weights.
Old May 29, 2009 | 09:49 AM
MBDiagMan's Avatar
MBDiagMan
5,200 would be a reasonable redline for a stock L98.
I hope that Aardwolf was running an improved flow intake system when he was spinning it to 6,000 RPM.
What is limiting this version of the 350 Chevy is the intake system. Anyone who has ever driven one knows that it seriously runs out of steam at about 4,500 RPM. This 5,000 RPM anemia is due to the TPI manifolds restrictions at that engine speed. This restriction causes SERIOUS tension on the rods at higher RPM because that engine is sucking for air like a Marathon runner wearing a gas mask. That increased load on the rods is SERIOUS and can easily lead to a broken rod.
Take that same long block and put a free breathing intake on top of it with no changes to the lower end and the Red Line could be safely increased significantly.
Doc
Old May 29, 2009 | 11:54 AM
GREGGPENN's Avatar
GREGGPENN
Just got back from Kmart with Iris. Now I have to decide if Nelly needs to go to Target around 12.
Oh yeah... that's why I was thinking a TPI was a better choice...No need to run it to 6000rpms on a regular basis. Beach Bum said 6k rpms could be done all day long for years....
Sounds iffy to me.
gp
Old May 29, 2009 | 12:08 PM
slickfx3's Avatar
slickfx3
ya right, although the mid and top end punch on my super ram is unbelievable,with my cam, it's been a bear to tune the idle off idle transition, but we are coming along, it smoothed way out, and the singlemass flywheel ding at the bottom end is starting to appear less appearent.
Old May 29, 2009 | 12:24 PM
GREGGPENN's Avatar
GREGGPENN
Doc
Do LTx cars use the same pistons/rods as late L98s (with their 700rpm higher ceiling)?
Old May 29, 2009 | 12:31 PM
bjankuski's Avatar
bjankuski
The short block can handle 6000 RPM without problems.
Old May 29, 2009 | 12:52 PM
mr.beachcomber's Avatar
mr.beachcomber
If you're using a stock cam, 4700 RPM is as high as you need go before shifting to the next higher gear ratio to keep your vehicle in it's best torque band.
Don't count on an ECM fuel cutoff to protect you from exceeding the self-destruct limit of the rotating assembly. From what I remember, the fuel cutoff for L98's is roughly 8000
RPM.
slickfx3's Avatar
slickfx3
The engine powers through the 5.5k no problem but my 3.33 gears, breaks all speed limits in second.
so I say depends on you tranny and rear end and intended usage, street? stay with siamesed SLP runners and port everything.
Old May 31, 2009 | 07:01 AM
MBDiagMan's Avatar
MBDiagMan
That is CORRECT! It just can't do it all the time, reliably with an L98 intake system on it due to the high RPM rod tension while trying to draw air through a straw.
I expect that the later LT engine has the same crank/rods. Again, the limitation is the restrictive intake system. It not only serves to limit the effective high RPM power, but also causes added stress for those who go beyond the redline.
To L98 Redline
