Summit Protorque Starter Shims
Old May 30, 2009 | 03:46 AM
ride250s's Avatar
ride250s
Default Summit Protorque Starter Shims
Anyone know how many shims I should run on my 87? I really don't want to drop my bell housing to find out...
Old May 30, 2009 | 08:32 AM
joe wilson's Avatar
joe wilson
It depends on what kind of starter you have and if it's been rebuilt. I've been told that you don't need shims if you have a new starter. The one I recently put on my 85 is a brand new mini-starter and I didn't use any shims and it worked just fine. I guess when they rebuild them they remove a slight amount of metal from the mounting surface to true them up, then they require shims.
Old May 30, 2009 | 08:38 AM
engle1147's Avatar
engle1147
Once you get the car up to a workable height it takes 1 minute to drop the dust shield....and just a few more to unbolt the starter to have a look.....maybe a bit longers if you have long tube headers
there should be "0" shims on OEM setup.
Old May 30, 2009 | 11:52 AM
ride250s's Avatar
ride250s
I think I may just try it with zero shims.
This is the mini starter I bought,
Summit Part Number: SUM-820323
To Summit Protorque Starter Shims
