Code Reader
Old Jun 1, 2009 | 04:17 PM
Bartman51's Avatar
Bartman51
Default Code Reader
I'm a new vette owner, i just picked up a a 1986 coupe with 78,000 miles.
it has been sitting for some time and I have changed the fluid's plugs wires cap, fuel filter. and has not started it turns over and starts when you pour fuel into the throttle body. after reading the forums I'm going to now replace the ECM. I dont have a code reader and would like to know what codes are in the computer, any help and suggestions would be greatly appreciated .
Pics to follow
Old Jun 1, 2009 | 04:30 PM
nutz4c4's Avatar
nutz4c4
You should first purchase the FSM to be able to trouble shoot it. Why is it you are going to replace the ECM?
Do not start throwing parts at it. Use a paper clip to read the codes if there are any. Use the advanced seach funtion for more info on the paer clip method
Perhaps Agent 86 will happen upon this and post a link for you
Old Jun 1, 2009 | 04:35 PM
Bartman51's Avatar
Bartman51
not to sound stupid but, i have no idea why to replace the ECM. Thanks for the Info.
Old Jun 1, 2009 | 04:42 PM
TA's Avatar
TA
Get one of these:
Then read this:
http://www.corvettephotographs.com/c4vettes/ecm.htm
Old Jun 1, 2009 | 05:04 PM
nutz4c4's Avatar
nutz4c4
Why are you set on replacing the ECM? You say it starts if you give it fuel.Sounds more like a fuel delivery problem.Do you have fuel pressure at the rail? Are the injectors firing?
Old Jun 1, 2009 | 05:30 PM
Muffin's Avatar
Muffin
Can you hear the fuel pump run when you turn the key to RUN. That's the first ignition switch position. You should hear the pump for 2-3 seconds. If not check your Fuel pump fuse. Check this and get back to us.
Old Jun 1, 2009 | 06:31 PM
Bartman51's Avatar
Bartman51
Im not set on replacing the ECM, I dont want to replace some thing that still works. I will try the paper clip and let you all know how i made out.
Old Jun 1, 2009 | 06:40 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default Bartman
Hey, Welcome. You have a nice year vette. When you get it going, your going to like it Lots of nice folks that will share their knowlage with you
Corvette Mike
Old Jun 2, 2009 | 07:54 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Welcome Aboard
Save these to your hard drive. As stated by some nut, sounds like a fuel delivery problem.
http://members.shaw.ca/corvette86/Co...0View%2086.pdf
http://members.shaw.ca/corvette86/6E3-B%20Symptoms.pdf
http://members.shaw.ca/corvette86/En...ButWontRun.pdf
http://members.shaw.ca/corvette86/Fu...l%20System.pdf
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
http://members.shaw.ca/corvette86/No...it%20Check.pdf
http://members.shaw.ca/corvette86/Ig...System-EST.pdf
Old Jun 2, 2009 | 11:16 AM
Bartman51's Avatar
Bartman51
Thanks Guys, I will update the status this after noon, glad to be aboard....
Old Jun 2, 2009 | 03:45 PM
nutz4c4's Avatar
nutz4c4
Old Jun 2, 2009 | 08:51 PM
AGENT 86's Avatar
AGENT 86
Originally Posted by nutz4c4
Old Jun 2, 2009 | 09:00 PM
ant-knee470's Avatar
ant-knee470
How long the car sit for?
Fuel sending unit maybe sitting on the bottom of the tank,
Maybe the fuel pump relay took a dump,
First check to see if the fuel pump is running.
If not maybe its not getting power..
The problem is in the fuel system..
Ant....
Old Jun 2, 2009 | 10:30 PM
Bartman51's Avatar
Bartman51
My brother in law with out my knowledge took the wires off the cap and block and rewired he believes that the passenger side goes 1-3-5-7 from front to back 2-4-6-8 from front to back. little help with that, and i hear the fuel pump click on for a second and also smell fuel when i crank the motor. that's all i got so far.
bummed out right now, but thanks for the help guys.
Old Jun 3, 2009 | 08:36 AM
AGENT 86's Avatar
AGENT 86
Originally Posted by Bartman51
My brother in law with out my knowledge took the wires off the cap and block and rewired he believes that the passenger side goes 1-3-5-7 from front to back 2-4-6-8 from front to back .
This ain't no Ford
http://members.shaw.ca/agent86/Spark...g%20Wiring.pdf
Old Jun 3, 2009 | 08:44 AM
Bartman51's Avatar
Bartman51
I figured that, fixed the plugs but no start, motor turns over and smell gas when cranking. Thoughts
Old Jun 3, 2009 | 08:52 AM
AGENT 86's Avatar
AGENT 86
You need a fuel pressure gauge to diagnose fuel delivery problems. Do you have one ??
To Code Reader
Old Jun 3, 2009 | 09:59 AM
Bartman51's Avatar
Bartman51
No I don't have a pressure gauge what else could I do??
Old Jun 3, 2009 | 10:14 AM
AGENT 86's Avatar
AGENT 86
Buy, rent, or borrow a gauge. You first need to know if you have sufficient fuel pressure, to allow it to run. Then your going to have to see if the injectors are actually trying to inject. A noid light is required to test the injector signal.
Old Jun 3, 2009 | 07:04 PM
Bartman51's Avatar
Bartman51
i didnt get a pressure gauge yet, but the car ran today for about 1min with the help of little starter fluid, when I hit the gas very little it bogged out and that was it. the low coolant light is on and the ABS light flashes 3 times and then turns off. Also the volts display is red next to the numbers if that means anything. also the shrader valve didnt have pressure after i cranked the motor
