Heads and cam!
Old Jun 2, 2009 | 04:12 PM
pearlvett's Avatar
pearlvett
Default Heads and cam!
I want to do a head and cam combo on my 85 corvette for about $650. What is the best combo and will it be safe to do on a car with about 170000 miles on it? Thanks ahead of time!
Old Jun 2, 2009 | 04:29 PM
Mojave's Avatar
Mojave
Uhhh what? You want to buy a pair of heads, cam, and all the parts you need to install them on an engine with 170K miles for $650?
Bad news, it will cost more than that.
Old Jun 2, 2009 | 04:34 PM
pearlvett's Avatar
pearlvett
I have already found heads for under $600 most cams dont cost more than $150 with lifters and gaskets are nothing. Now explain to me why this isn't possible? I asked for good combos and if my engine could handle it nothing else.
ch@0s's Avatar
ch@0s
I would not tear and engine half way down with 170K without doing a rebuild.
$650 is one half of a cam head budget
Old Jun 2, 2009 | 04:37 PM
ch@0s's Avatar
ch@0s
you have already gone $300 over with hoses, gaskets, fluids, cleaners etc..
and you will run into other things you need, ask me how I know
I think 1000-1200 is a more realistic goal.
pearlvett's Avatar
pearlvett
Im not lookin at the multi thousand dollar heads that most people are buying on here. I cant afford to do a rebuild right now and i need atleast the heads done before i leave for college in the fall. I would appreciate some input on atleast the heads and i can find a cam to match.
Old Jun 2, 2009 | 04:40 PM
pearlvett's Avatar
pearlvett
I have all of the cleaners and gaskets that i need. Im not replacing the hoses if their not bad. I wouldnt have put that number on here if i didnt KNOW it was possible. Im not an idiot i just wanted the opinion of people on here that have done a head and cam swap so i can find the nest combo for the money.
Old Jun 2, 2009 | 04:42 PM
ch@0s's Avatar
ch@0s
I am not trying to insult you .. just help
Old Jun 2, 2009 | 04:45 PM
92ZR1WANNABE's Avatar
92ZR1WANNABE
That money might be better spent by simply refreshing the top end. The valve springs / seals and gaskets.
Save the extra money for down the road when you can really do what you want to do.
I would think 170k Mile valve springs are crying a little bit at higher RPMs.
On the flip side, if you can find complete heads (used maybe) and a cam and associated hardware needed for the swap , then heck ya go for it.
Old Jun 2, 2009 | 04:55 PM
ch@0s's Avatar
ch@0s
Old Jun 2, 2009 | 05:08 PM
bjankuski's Avatar
bjankuski
Buy set of used or rebuilt 113 Vette heads for around $400.00 (These were used on 1988 through 1991 vettes and GM crate engines to present day). Then pick up a flat tappet cam and lifters with specifications of 210 to 220 intake duration at .050, 215 to 225 exhaust duration at .050 on a 112 CL with lift around .450.
This should come in near your budget and give a performance boost.
Old Jun 2, 2009 | 05:29 PM
383vett's Avatar
383vett
113 heads with the 58cc chambers would result in a high compression ratio with the flat top pistons he had now on the 85. Not a good idea. The cam numbers are in the right area. To the original op; it doesn't make sense to change heads and cam and not change routine parts like the water pump, hoses and belt. Just removing 170,000 mile hoses will probably tear them. You have to think about reliability at this point. If you are going to use the car as transportation at college, make sure everything is in good solid shape and you will be happier in the long run. Getting stuck on the side of the road at night with a blown hose is not fun.
Old Jun 2, 2009 | 05:37 PM
Mojave's Avatar
Mojave
I think it's silly to do a heads and cam swap and not do it right, which includes all the stuff that needs replacing (like hoses, water pumps, intake gaskets, injectors if needed, maybe even the whole intake...) and getting it dyno tuned to take advantage of the changes.
Old Jun 2, 2009 | 05:58 PM
Muffin's Avatar
Muffin
Got to agree with my Aggie Buddy here.If I were about to go off to college I think my main concern would be in a reliable engine not one "hopped up"with the cheapest parts I could find. IMHO 170,000 miles and reliable don't belong in the same sentence. I would opt for maintenance items to get me thru the year. If you are in college and are driving a Corvette that alone is sufficient to impress the ladies.
Old Jun 2, 2009 | 06:07 PM
rickneworleansla's Avatar
rickneworleansla
Old Jun 2, 2009 | 06:31 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If you KNOW it is possible why are you asking us?
Old Jun 2, 2009 | 06:32 PM
steven mack's Avatar
steven mack
You can get some cheap Chinese Pro Comp heads on fleabay. Flat tappet cam and lifters pretty cheap. A cheap gasket set.But it's still going to cost more than $650.
To Heads and cam!
Old Jun 2, 2009 | 08:00 PM
pearlvett's Avatar
pearlvett
Because most of the guys on here know and have experience with the parts that work well on the engines. I was hoping to find someone that is in the same situation as i am at one point in time with my money situation. I just wanted some opinions on heads. On that note what if i take some 2.02 heads and have them rebuilt. They would flow better than the heads on my car right now anyways right?
Old Jun 2, 2009 | 08:46 PM
aboatguy's Avatar
aboatguy
Cheap Reliable Fast Pick two
Good luck! and don't forget supporting mods (bigger cam often needs a stall for a4 and gears or just gears for manual)
A quality tune costs almost your entire budget and if you end up making big power you are guaranteed to find the next weak link in your car. Roaching the tranny can easily eat 1200 bones. A Precision industries Vigilante converter will eat your entire budget.
Used parts may be your answer but I'd save my money until I had about four times your current budget, since grenading your short block will take about double your current budget just to fix the short block, its better to have an oh schitt fund if you have a toy.
Remember a good rule of thumb is figure out what you want to do, price each part IOT get and estimate and then double or triple it and you may end up in the ball park, especially with a 170K project.
Sell your old 46X double humps they are not as good as a more modern aluminum head.
It actually looks to me like no one is trying to bust your chops they are trying to save you some heart ache.
If your budget really is 3 digits and you really really have to dig into something, I agree with the suggestion that you change your valve springs and seals and leave the rest of the money alone for the OHHH SCHITT fund.
Mike
Old Jun 2, 2009 | 11:41 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
I just finished my top end and it was over $3000.
