Heads and cam!
Good luck! and don't forget supporting mods (bigger cam often needs a stall for a4 and gears or just gears for manual)
A quality tune costs almost your entire budget and if you end up making big power you are guaranteed to find the next weak link in your car. Roaching the tranny can easily eat 1200 bones. A Precision industries Vigilante converter will eat your entire budget.
Used parts may be your answer but I'd save my money until I had about four times your current budget, since grenading your short block will take about double your current budget just to fix the short block, its better to have an oh schitt fund if you have a toy.
Remember a good rule of thumb is figure out what you want to do, price each part IOT get and estimate and then double or triple it and you may end up in the ball park, especially with a 170K project.
Sell your old 46X double humps they are not as good as a more modern aluminum head.
It actually looks to me like no one is trying to bust your chops they are trying to save you some heart ache.
If your budget really is 3 digits and you really really have to dig into something, I agree with the suggestion that you change your valve springs and seals and leave the rest of the money alone for the OHHH SCHITT fund.
Mike
fully!
As for the heads/cam budget... I'm in the middle of a heads/cam deal on my 92 vette right now. I didn't buy new heads, I had my old ones refurbed and finally tried something I've always been curious about, head porting. Anyway, the real reason for my post is to show you a real world parts list for a heads/cam project with real world pricing. My target was $1500.
PS, I swear if you show my wife I'll hunt you down.
Description, part # Price
Valve springs CC914 $120.00
Retainers CC941 $55.00
Hedman street hedders HED-68440 $160.00
.021 head gasket SCE-011062LT $88.00
Subtotal $423.00
3000 stall 9.5” torque converter $550.00
Subtotal $550.00
Cryo treated Strange 3.73:1 Dana 36 $650.00
Subtotal $650.00
PCMFORLESS custom chip program $204.00
Subtotal $204.00
1.94/1.50 swirled back cut valves $160.00
Machine work, recondition heads $368.00
Subtotal $528.00
LT1 cap & rotor MSD 4381 $140.00
Taylor 8.2mm plug wires $69.00
CSR Electric Water Pump $184.00
Royal Purple 75W90 gear oil (2 qts) $36.00
Royal Purple Dex III ATF (5 qts) $65.00
Royal Purple 5w30 Engine Oil (5 qts) $40.00
ARP LT-1 cylinder head bolts $86.00
Shipping $12.00
LT1 MSD blaster coil $43.00
Hardened pushrods $32.00
Subtotal $706.00
Axle & Drive Shaft Universal joints (3) $60.00
Timing Chain $20.00
Subtotal $80.00
Total Purchased $3141.00
the "oh yeah" stuff cost the most
Buy a set of valve seals and valve cover gaskets and just replace the seals.
Save your money to do a heads/cam swap the RIGHT way... You'll be money ahead, not to mention you won't be "bubba-fying" your engine with old dinosaur used heads. That is, if you want it to be reliable (as reliable as a 170K Vette can be).
Best of luck to you
If you are fixing valve seals (I'm doing the same) It would be timely to put in new springs and 1.6 rockers while you are there. Others that have done that seem to say between 10-20hp from this.
Pulling the heads is quite a bit more work - but If you are not afraid of the effort - you can get a good look inside to see where you stand, and port matching - perhaps a basic bowl blend would help!!!.
Mike
Joe B.
The car will last a couple of years if you just stay on top of the basic maintenance and fluids...you don't have to baby it....do the mods you opened the thread up with down the road. Good luck with the schooling.The top end of an engine is the most expensive part. I have purchaced all the above and probably have $2500 invested so far and haven't purchased plugs, oil & filters yet. I had to buy a few tools as well that I hadn't planned on. Best thing to do is save up and buy everything you will need for the job before starting in on it.
fix the problem and get your cam too
