Full Throttle Problem
Old Jun 3, 2009 | 11:14 AM
JimmyS5600's Avatar
JimmyS5600
Active Streak: 90 Days
Default Full Throttle Problem
Hi All,
Just had my 96 out and if you manually hold the trans. in first (auto)
it bucks/hesitates after about 5k,better on gear change to 2nd but returns after 5k again. Doesn't seem as bad if floored in fully automatic operation. Iam confused,any advise?
Old Jun 3, 2009 | 01:51 PM
383vett's Avatar
383vett
It could be wires or plugs if they haven't been changed in a while. Other possibilities are valve springs, fuel filter or pump. Has it been tuned up lately?
Old Jun 3, 2009 | 02:05 PM
c-4 lhozwalte's Avatar
c-4 lhozwalte
is the asr off?
Old Jun 3, 2009 | 04:22 PM
JimmyS5600's Avatar
JimmyS5600
Yes asr was off. I understand when you mention plugs or wires,it isn't a miss. It is like a bog at higher rpm,kinda weird. It only has 17k on it.
Everything is original and like new. Fuel pump was my thought too because how it feels when it does it. "Normal" driveing it is fine. Only on very hard acceleration. It does it to a certain degree when you hit passing gear also.
To Full Throttle Problem
