Just recieved mine today can't wait to get everything all installed. Just need to call and make appointment now.
Is anyone running this stage 2+ with alum. flywheel with zf?? I know it's a little late now that I have it but just curious to hear some stories about the combo.
CF member BlackHarleyMan, has a SPEC Stage 2+ in his 96. He bought the Spec steel single mass FW because he thought it would make less noise than the Alum. He dislikes the noise but loves the clutch.
I don't know what it weighs but I'll do it within the next couple days. SPEC rep. stated the alum. FW is 13-16 lbs. I think the DM is 32-36lbs.
I worried about the noise a little bit but the car isn't driven that much. Rarely do I take the car to go no where. I go to judged shows, cruises and the dragstrip. Maybe 1000 miles a year.
So as of now I'm gonna install:
SPEC stage 2+ clutch/alum. FW
B&M Ripper shifter
Newmans Car Creations complete rearend with 3.73's (thicker rearend)
DRM camber and trailing arms
HyperTech Coil
New Plugs/Wires
