Optispark
Old Jun 11, 2009 | 05:16 AM
nobull66's Avatar
nobull66
Default Optispark
I was driving home from work and got stuck in a bad storm on the freeway. I hit a big puddle of water and the car started jerking when i gave it gas it did this for about 30-50 sec then stop. Did i hurt the optispark?
Old Jun 11, 2009 | 07:30 AM
pcolt94's Avatar
pcolt94
That’s a hard question to answer accurately. Your assuming it was the opti but maybe problem could be another source. Hot coil wire could ark out at either end with excess moisture. The opti is pretty well shielded in there and you would need an huge amount of water coming in. However worse case for the opti would me carbon tracking in the cap causing a permanent effect.
There is not way to tell the health of the cap but if it is running normal now I would leave it along. If something in the future develops handle it then.
Old Jun 11, 2009 | 09:27 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
It may go away after things dry out.
If not your going to have to pull it apart and get the water out.
Old Jun 11, 2009 | 09:31 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
What year Vette? Early Optis on 1992 and '93 models were unventilated and most susceptible to moisture intrusion. Later models had a vacuum line designed to suck moisture out of the unit using intake pressure.
Old Jun 11, 2009 | 09:34 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
That happened to me with my 92 Vert. Yes, the opti took a bath. I remember, the Vert started a minute later.
Is your Vett back to normal?
Old Jun 11, 2009 | 01:00 PM
nobull66's Avatar
nobull66
It's a early 93 model.
Old Jun 11, 2009 | 01:03 PM
nobull66's Avatar
nobull66
It's running fine now.
Old Jun 11, 2009 | 01:09 PM
MikeC4's Avatar
MikeC4
Then you are probably fine. Water probably hit the high voltage lead either at the coil end or Opti connection. You may want to check these 2 connections as well as the 8 spark plug leads that attach to the Opti.
Old Jun 11, 2009 | 01:45 PM
onedef92's Avatar
onedef92
Do you have more than 60,000 miles on your O.E.M. Packard coil and plug wires? If so, I'd consider swapping them out for a new set.
Old wires are susceptible to electrical shorts when they get wet due to the loss of their insulation properties.
You can order the looms and wire holders, too, online from Mid-America Motorworks (MAM).
Old Jun 11, 2009 | 01:58 PM
MyFatNutz's Avatar
MyFatNutz
I know this is a 93, but I want to share this because it's somewhat related. I had a problem with my 95, the vented opti, where the vacuum line was rubbing up on one of the pulleys which wore a massive opening in the line. When I replaced the opti, shortly after for the above symptoms, there was a ton of moisture in there and plenty of carbon tracking. There is a TSB with the fix for this. I wound up getting the recommended bracket and new vacuum lines and all has been fine ever since, even with 2 water pumps pissing all over them.
Old Jun 11, 2009 | 02:25 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
It is fine, I have been running through puddles like yours for years in my vette, it will hesitate for a few seconds and then be fine.
Old Jun 11, 2009 | 02:44 PM
LBYRNES's Avatar
LBYRNES
I have a '93 and I've lost 3 Optisparks to puddles.
Old Jun 11, 2009 | 04:24 PM
skybolt31's Avatar
skybolt31
What kind of optisparks did you loose, OEM, MSD, Dynaspark, other?
To Optispark
