Engine Replacement for my 84
Pull the heads and look at the cylinder ridge. If there is very little ridge, then there is probably not a lot of cylinder wear. Pull the pan and the pistons and mic the cylinders and crankshaft. Unless the engine has never seen frequent oil changes or has been driven REALLY crazy, the odds are very good that things will be in tolerance and simply replacing rings and engine bearings will put the short block back in good shape.
In the old days this was called an in frame overhaul and was an accepted maintenance/rebuild method. In those days, with carburetors and the poor oils that were available the cylinders were often toast at 100,000 miles. Today with far superior oil and fuel injection limiting the amount of oil washed of the cylinder walls during cold starts, bottom ends are good for at LEAST twice the mileage as those of old.
The Small Block Chevy is an engine that has always lent itself to reringing. The odds are HIGH that this would get your engine as good as new.
If it turns out for some reason that your engine is indeed worn out requiring a short block, you will not have wasted much work because you will have it to a point where a short block could go in quickly.
Good luck,
Doc
There are many advantages to taking this approach:
You will keep the factory balance - unless you spring for a really expensive short block it will probably not be balanced.
It will maintain a numbers matching car. Who knows, these cars MIGHT be worth something some day.
There is almost no additional power to be gained from the short block. The vast majority of power is determined by the heads/cam/intake package.
It would save lots of money.
You would have the pride that you know that you made it all like new YOURSELF!
Doing an inframe overhaul in some ways would be easier than changing out the short block. Once the heads are off, which they have to come off anyway, you simply pull the pan (fifteen minutes on these cars,) unhook the rods and push the pistons out. Make sure all pieces are marked so they go back in place in all the same positions. Mike the cylinders and journals which will probably be fine, then put it back together with new rings and rod bearings. If you've had any oil pressure issues, replace the main bearings while it's apart. For peace of mind replace the oil pump. At that point you have a fresh, balanced short block without having to remove and replace it.
In a Vette because of the engine setback and difficulty of reaching bellhousing bolts, reringing the block in frame may very well be no more hassle than changing the short block.
AGAIN, don't put the cart in front of the horse. You guys are already talking about boring the block before you have even MEASURED IT!
Diagnosis before TREATMENT!
Doc
Doc
I put 58 cc heads on my 86, and the compression is almost 10.5:1. it runs just fine if you don't do drag racing. The engine does not burn any oil, and it's the basic same engine you have with a 1 piece rear main seal.
The short blocks you see advertised that go from 290 horse up to 255 horse don't all have compatibility with your fuel injection system.
A 350 block is a 350 block is a 350 block. Some have roller cam provisions and 1 piece rear seal changes, but that's it. You can make yours a roller cam block, it's just more expensive. Less expensive than a new block. But if you want a new block, go for it. IF I were you, I would get a zz4 short block, and put everything you have on it, depending on the size of the head combustion chambers. If you need 58cc for the ZZ4 dished pistons, you have other choices depending on what heads you bought.
your cam is 82 and 84 specific. you will have to have a chip burned for your car if you change cams for big horses.
Your car was designed for cruising 75 mph at 1800 RPM. you are going to get into stall speed changes in a converter, and rebuilding your trans.
Decide what you reallly want to do, because there is a action-reaction going to occur when you start overstressing the original parts, and from now on, it is going to get expensive.
Remember this, you already have about $2000 plus purchase price tied up in a car worth $5000 or less, and no matter what you do, you will receive $100 back on every $1000 you spend when you go to try to sell it.
Why are you "sending it out" when you can do it yourself and obtain the same thing??
Rings not seating? I did a 68 Chevy Truck just as Doc suggested in a single Saturday.
A smoking worn motor ran like a scalded dog afterward. The Truck was sold to another kid ( I was a kid) in that town and I kept up with my rebuild for at least 4 years...then the truck was sold to someone I didn't know and I don't know what happened to it after that.
What was Docs original suggestions?? Check the cylinders to see if they are in or out of tolerance....Key phrase being "and mic the cylinders and crankshaft"
If you send the Block "out".....All they are going to do is check the tolerances themselves anything that is still within spec, they aren't going to touch...they'll slap it back together and "LEGALLY" call it rebuilt.
So some hourly wage kid checking the specs is better than you how??
If you want to punch it out .030" over...then state that.
If you only have a 127 piece tool set from Kragen....state that as well.
If you'd like to pull it and paint the block and shine up all the pieces state that as well.
If you'd like to fix the problem and drive on, You have a good suggestion.
That said, since the late seventies I have YET to hone a cylinder during an in frame and I have YET to have rings not seat. There is ONE stipulation though, and that is the use of cast iron rings.
RYDER Truck Rental at that time operated one of the largest vehicle fleets in the world, second only to the US Government. Ryder labs did EXTENSIVE research and determined that the best way to in frame was the use of cast iron rings on a glazed, but of course in spec, cylinder wall. THIS WORKS and works WELL!
Reringing an engine without breaking the glaze is against old school wisdom but it WORKS!
I had occasion once to see an engine that had 400 miles since a cast iron ring, glazed cylinder overhaul, be taken apart. It was taken apart for a reason besides piston/cylinder issues. Every ring in the engine had obviously seated well.
Newer design engines are not commonly overhauled for many reasons, but the old SBC is a GREAT candidate for this. And the installation of it in a C4 chassis is one of the few since 1957 on which the pan comes off easily.
If you want to spend thousands of dollars building an engine for a car that is worth not much more than that, then removing the engine and doing some quality machine work, rebalancing and all that, then sure, you SHOULD get a great result, but this is a situation that's a natural for a good old fashioned in frame overhaul.
BTW, a "dingle ball hone" as you call it, originally known as a glaze breaker, is just THAT, a glaze breaker. In the case of an overhaul, the hone is ONLY used to break the glaze, not size the cylinder in any way as you would do with a CK10 or some such. There again, NO HONE or glaze breaker is necessary anyway. Just use cast iron rings.
Doc
On the other hand, to change short blocks you will need a Harmonic Balancer puller and a cherry picker or chain hoist for pulling the engine.
It would probably cost less for tools to do an in frame than it would to change the short block.
If you've never done bottom end engine work, you will need to learn a few things, but there is probably no shortage of books named something like "How to Overhaul Your Small Block Chevy" that will give you all that you need to know.
Best of luck with it,
Doc
If he wants the bottom end done then so be it. Don't throw a job at him that he may not be ready for. Sorry but your not gonna do this job with a ratchet set and screwdriver.
By the time you remove the top end, oil pan and everything else, you could have just pulled the engine and already have it at a machine shop and half done, or after you remove all that found out you needed to pull it anyways.
Sorry guys but not everyone is equiped with everything needed to do a rebuild. Remember they would have to buy tools ontop of what they want done and could be down twice as long.
http://www.paceparts.com/
new/cheap/warranty
Sure you can do a poormans hone and use cast rings..it will help, but really...Your motor is 25 yrs old, I bet the cyls have gone slightly out of round by this point and honing wont bring that back. Pulling a motor in a C4 is a lot of work...Hate to see you go through that only to find somethign went wrong with your rebuild. Unless youre a real good wrench and have done motors before get a new one and eliminate the varaibles.
new/cheap/warranty
He is pulling the heads ANYWAY! If he is capable of doing the heads and intake, pulling the pan, disconnecting 8 rods, pushing out 8 pistons and getting everything back together properly is doable for him IF he feels comfortable with what he has to learn.
cuisinart,
Yes indeed this is a 25 year old engine, but it is an INJECTED engine! Cylinder and piston life were RADICALLY improved with the advent of fuel injection. The old carburetors were dumping raw fuel into the cylinders at every cold start, washing the oil off the cylinder walls. FI probably extends piston/cylinder life by a multiple of at least three. UNLESS the engine has not seen a reasonable oil change interval or has been driven REALLY crazy, at this mileage the odds of in spec cylinders are quite high as are the odds of a reusable crank.
All,
No, this is not a 20 minute job done with a pair of pliers and a screwdriver, but it doesn't require a big, full Snap On box either.
inex1 needs to make his own decision. If he is drawn toward a challenging, but rewarding DIY project and has someone to ask questions and is able to digest information in an overhaul book, this is a good solution for him.
I am trying to encourage him to look into it and challenge himself. He's not trying to build a Pro Stocker. He's ambitiously trying to improve his somewhat modest, but fun car. He has shown that he's up to a challenge by doing the top. That's easily more than half of the work of an in frame on one of these cars.
For an in frame, you're not pulling anything off the front or the back of the engine. The C4 Vette leaves the block quite accessible once the heads and intake are off.
Keep researching this inex!
Doc
good luck.
Personally I understand the point that your trying to make and I don't disagree with your point. And I do agree that he needs to research it before making is mind up. I'm being just as truthful as you but I'm on the other side of the fence.
Would I like to learn how to tear my internal apart ...yes. Do I have a book that tells me how to do it...yes. But when push comes to shove I really don't have the time. So for me I either send it to a machinist or buy a new block. Those options have warrentees, my workmanship with zero experience as none. So I'd be pretty upset it I had to tear it down a second time. Anything else on the car I don't have a problem with.
To the op, if you do it Docs way that great, but just know that your not gonna do it in a day, and at times you will be frusterated. Then come back to the forum and pm all the guys that told you to do it yourself...
