My High Tech 4+3 Jack Adapter
Old Jun 16, 2009 | 07:53 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Originally Posted by 383vett
Now start working on that jack. Do you ever put it away IN the garage?
No, it's spent a lot of time outside, where all my previous projects took place.
Paint is in it's future.
Old Jun 16, 2009 | 07:55 PM
AGENT 86's Avatar
AGENT 86
Originally Posted by jhammons01
^^So when you did that, you basically unhooked the electronics and the TV cable....The Shifter linkage....four bolts that connect it to the Bell housing and out the thing slid???
Was there wriggling to get it to release?
Yes, except 86 doesn't have the TV cable. It popped out without a hint of grief, unlike the C beam.
Old Jun 16, 2009 | 11:28 PM
jhammons01's Avatar
jhammons01
^^I'm pulling mine out this way, maybe tomorrow or the next.
Old Jun 17, 2009 | 08:10 AM
AGENT 86's Avatar
AGENT 86
Do you need the CAD drawings for the adapter.
Have fun !!
Old Jun 17, 2009 | 09:34 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Originally Posted by AGENT 86
Bell was still bolted to block.
I'm doing the clutch, short throw arms and checking out the syncros and shift forks. About once a month, she pops out of 1st or 2nd, during a decel.
Mine was poping out of 2nd during decel also. I assumed that it was just worn syncros or a bad adjustment on my short throw shifter arms. In an unrelated action, I changed the tranny oil & replaced it with Royal Purple 70w-90w gear oil and it has NEVER popped out of gear since. This was over a year ago now & still no popping out of gear. The tranny is significantly quieter and shifts MUCH smoother with the Royal Purple; also no leaks. GO FIGURE?
FWIW
Old Jun 17, 2009 | 09:45 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Is this the overdrive lube fill hole? If so, do you just add auto tran fluid until it reaches the top of the plug hole? (click to enlarge photo)
Old Jun 17, 2009 | 10:26 AM
jhammons01's Avatar
jhammons01
^^Yup, you just put ATF in there until it is full (or spills out that same hole) and then button it up.
I forget which type of ATF
AGENT 86's Avatar
AGENT 86
Old Jun 18, 2009 | 07:04 PM
jhammons01's Avatar
jhammons01
You never did say, why are you pulling your tranny?
Old Jun 18, 2009 | 07:29 PM
AGENT 86's Avatar
AGENT 86
See post 17
Old Jun 18, 2009 | 08:14 PM
jhammons01's Avatar
jhammons01
you did say that didn't you......
Are you uncoupling the 4x3 from the Super T10?? Do you have one of those nifty .pdf files for me that shows me what to do??
Old Jun 18, 2009 | 11:00 PM
AGENT 86's Avatar
AGENT 86
No, I was going to, but I have decided I don't want to open a can of worms, this late in the year. I will leave it to a REAL winter project and hope that a linkage adjustment may help. The pop out is so scarce, that I'm not too concerned.
I will upload the stuff you want and PM you a link.
Old Jun 18, 2009 | 11:11 PM
  #33
383vett's Avatar
383vett
Can I have a copy too in case I switch back to a 4+3?
Old Jun 18, 2009 | 11:16 PM
  #34
jhammons01's Avatar
jhammons01
Thanks Maxwell ....I'll be on the watch
I've been trying to crack them apart just now...they don't seem to want to give in and let me open it.....maybe the pdf will have a step within that I am passing up
Old Jun 18, 2009 | 11:29 PM
  #35
AGENT 86's Avatar
AGENT 86
http://members.shaw.ca/dankai/Manual...0Overdrive.pdf
Old Jun 19, 2009 | 01:46 AM
  #36
jhammons01's Avatar
jhammons01
Thanks again 86
Old Jun 19, 2009 | 08:23 AM
  #37
LD85's Avatar
LD85
Patent Pending ?
To My High Tech 4+3 Jack Adapter
Old Jun 19, 2009 | 03:21 PM
  #38
AGENT 86's Avatar
AGENT 86
Originally Posted by LD85
Patent Pending ?
No, but I am willing to sell the rights.
Old Jun 19, 2009 | 06:11 PM
  #39
jeffp1167's Avatar
jeffp1167
I think before you start counting the money you need to first start detailing that jack. Maybe chrome the wheels, powdercoat the jack in a nicer color. Then maybe add some wood stain to really compliment the package.
after that man I see pure profit .....
nice work though if I ever gotta do my 700r4 thats what I will try.
Old Jun 25, 2009 | 10:49 AM
  #40
jhammons01's Avatar
jhammons01
It's looking at me...
