My High Tech 4+3 Jack Adapter
Old Jun 15, 2009 | 10:15 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default My High Tech 4+3 Jack Adapter
I spared no expense, I mean there was no expense.
I welded 4 nuts to the jack cup and made a plywood mount.
Old Jun 15, 2009 | 11:15 PM
pianoguy's Avatar
pianoguy
Pretty slick!
Old Jun 15, 2009 | 11:40 PM
383vett's Avatar
383vett
Damn, that does look hi tech. Can I order a dozen? The car looks great by the way
Old Jun 16, 2009 | 08:25 AM
AGENT 86's Avatar
AGENT 86
I can't spare the 30 minutes to make a dozen, but I can send you a CAD drawing.
Thanks for the kind words, the camera takes 20 years off.
Old Jun 16, 2009 | 08:43 AM
jeffp1167's Avatar
jeffp1167
those polished or chrome 90 wheels?
Old Jun 16, 2009 | 08:44 AM
Caboboy's Avatar
Caboboy
I miss the poor man's shed
Old Jun 16, 2009 | 09:41 AM
engle1147's Avatar
engle1147
Damn that is high-tech!
You know that tranny is going to need some yellow paint before it goes back in.
Old Jun 16, 2009 | 10:09 AM
AGENT 86's Avatar
AGENT 86
Polished 90 ZR1's
Old Jun 16, 2009 | 10:11 AM
AGENT 86's Avatar
AGENT 86
I don't !!
Tim
Old Jun 16, 2009 | 10:15 AM
383vett's Avatar
383vett
Would it be a good idea to bevel the edges just to make it more trick? Can this whole assembly be painted yellow?
Old Jun 16, 2009 | 10:31 AM
jhammons01's Avatar
jhammons01
I'm just curious, where is the bell housing?
And why again are you pulling the tranny?
Old Jun 16, 2009 | 10:51 AM
383vett's Avatar
383vett
I bet it's still in the car attached to the motor.
Old Jun 16, 2009 | 11:02 AM
jhammons01's Avatar
jhammons01
Is that "easier"???
I guess every time I've pulled one, it was to get to the clutch and replace it.
If you are just after the tranny (and the clutch is fine).....looks like 4 bolts and you are free.
Old Jun 16, 2009 | 11:45 AM
MK 82's Avatar
MK 82
Shadetree engineering at it's finest!
Old Jun 16, 2009 | 12:31 PM
jhammons01's Avatar
jhammons01
Agent86, what is holding up the Bell housing?
Old Jun 16, 2009 | 02:36 PM
powerpigz-51's Avatar
powerpigz-51
That rocks! I had to use 2 jacks at the same time when I did mine, and my arms were sore in places that i didn't know existed when I was done. Very cool.
Old Jun 16, 2009 | 03:23 PM
AGENT 86's Avatar
AGENT 86
Bell was still bolted to block.
I'm doing the clutch, short throw arms and checking out the syncros and shift forks. About once a month, she pops out of 1st or 2nd, during a decel.
To My High Tech 4+3 Jack Adapter
Old Jun 16, 2009 | 03:25 PM
AGENT 86's Avatar
AGENT 86
Is that "easier"???
It's a lot easier to remove the bell bolts after the trans is out of the way.
Old Jun 16, 2009 | 03:41 PM
jhammons01's Avatar
jhammons01
^^So when you did that, you basically unhooked the electronics and the TV cable....The Shifter linkage....four bolts that connect it to the Bell housing and out the thing slid???
Was there wriggling to get it to release?
383vett's Avatar
383vett
Now start working on that jack. Do you ever put it away IN the garage?
