Coolant Leak
Take a look at this pic of a surge tank where ive labled the connections:
That is for a later model than an L98 system, but the relevent parts should still be easily related. Check all around this area, especially the 2 big connections on the bottom side of the surge tank, and also the delivery line to the heater core, cause i reckon around this area is where you may find your leak.
I find it hard to believe it could leak ouside the car if it was the heater core and not either
A: smell of hot coolant inside the car, and B: leak from the HVAC system onto the carpet.
That is not to say it wont, but i find it hard to believe it could.
If that is the case, the leak is quite likely to be in that area, especially if the hoses are old or the surge tank its self is the factory original unit.
The "stream" does however, make it sound like something else.
Time to explore
It's an 86.
i had some antifreeze trickle down onto the passenger carpet and have read that a quick fix would be to bypass the heater core but my question is....does this fix also need to have the dash poulled out as if you were replacing the heater core and if so? why not just replace it if youve already gone through all that trobule of removing the dash? unless the hoses to do the quick fix are located under the hood without the dash having to be removed?
