Milling 113 heads
Old Jun 21, 2009 | 01:21 AM
ekess744's Avatar
ekess744
Default Milling 113 heads
my machinist had to take .030 off my 113's because of the warping around the seventh water port hole. IS the .030 a safe amount to mill off a 113 head?
Old Jun 21, 2009 | 03:02 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
One member I know in this forum had his done that amount. 1 yr later, he lost a head gasket. But, that was attributed to the multiple 1010 Felpro gasket failures (which he was using). Personally, I don't believe it was the milling.
FYI: There are companies that will mill that much off new heads to get smaller chamber sizes -- and I'm talking smaller than 56cc (like 53, 54, 55cc...). Check with other cylinder head shops. See if you can find one that says .030" is a problem.
Worst problem I can see is it brings your front & rear china walls about that much closer to the block. You might need to skip using those gaskets and go with 100% silicone.
Old Jun 21, 2009 | 03:38 AM
ekess744's Avatar
ekess744
I had already planned on going to a thicker head gasket so the a future head swap would be slightly easier, realizing that I would have to mill on something like a 64cc chamber quite a bit to keep compression similar to what I am going to have with the milled 113's
Head gasket failures is something I had heard rumors about from taking a head down too far. I just thought I'd double check with all the members here which seem to have a ton of 113 specific experience
Old Jun 21, 2009 | 03:33 PM
GREGGPENN's Avatar
GREGGPENN
The stock head gasket is plenty thick @ .051". I take it you're redoing the bottom end. Are you going with flat-tops or something?
Old Jun 21, 2009 | 04:13 PM
jeffp1167's Avatar
jeffp1167
the problem with over cutting a 113 is the intake valve. It sits very close to the surfaced area and if you mill them too much you can easily weaken the seat area.
Old Jun 21, 2009 | 04:32 PM
GREGGPENN's Avatar
GREGGPENN
Are you offering a guideline for how much they can be milled?
Old Jun 21, 2009 | 04:40 PM
jeffp1167's Avatar
jeffp1167
Nope just saying I don't think 30 is doable and if you could by cutting to much wouldn't you alter the angle of the intake port area and its ability to seal. I think these were cut to 20 thousandth's I'm not sure been awhile since I had them done. You can see how close it is now to the valve.
To Milling 113 heads
