[Poll]: Engine Rebuild Choices
Old Feb 11, 2002 | 09:43 AM
A's Avatar
A
Default Re: [Poll]: Engine Rebuild Choices (scorp508)
Based on the choices, I'm torn between 383 and 383 :lol:
Old Feb 11, 2002 | 09:59 AM
miker61588's Avatar
miker61588
Default Re: [Poll]: Engine Rebuild Choices (A)
how much money do you wanna spend?
Old Feb 11, 2002 | 10:15 AM
MrJay's Avatar
MrJay
Im going to rebuild mine to 396 when it goes, it does not cost that much more and not that much more work.
Jay
Old Feb 11, 2002 | 12:44 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
427 - Just so you can say you have one under the hood.
I do not believe there is enough meat on these blocks to go that far.
Drat - 383 then, that seems to be real popular for driveability as well as racing.
James
Old Feb 11, 2002 | 12:55 PM
dgoodhue's Avatar
dgoodhue
I would for a 383 over a 396 for a couple of reasons.
1) The SR and the heads you have are going to limit how much HP you can make.
2) You don't need any more torque.
3) You do a lot of driving and a 383 has a better rod stroke ratio and will last longer. (a 6" rod 355 will last longer than a 383 also.)
4) Cost, a Forged 383 kit (with a forged Scat Crank) is $1400, an all forged 396 kit is going run $2600+ (with the same exact rods/pistons). The more expesive crank are a better brand and quality, but even a Scat forged crank will be able to handle a 383 SR with a decent 150 shot N2O. BTW May there are cheaper 396 kits, but I haven't seen any. (I haven't look that hard though either)
Old Feb 11, 2002 | 01:04 PM
scorp508's Avatar
scorp508
The engine in the car is going forward as planned whenever I get off my butt. This new one is going to be something else. I am not sure what. Maybe I will just rebuild it to a 355 L98 completely stock as a backup. I do not know.
Although the idea of taking my time and accumulting the parts for a low compression 383 or 396 and dropping a supercharger on do sound tempting. :)
Old Feb 12, 2002 | 03:17 AM
ChrisB's Avatar
ChrisB
Default Re: (scorp508)
If you do a supercharger then I would stick with a 383 for ring stack height consideration. Otherwise go for as many cubes as you can get. Even with the same intake, etc. Even if the 396 was so choked by the intake that it didn't make *any* more power (which I don't think is too likely) it will make the same power at a lower rpm - have a flatter torque curve, etc.
If you go with forged parts, quality 383 stuff costs the same as 396 stuff - the only real price break comes from using a cast crank (which is perfectly fine) - though that limits you to a 383.
Old Feb 12, 2002 | 05:10 PM
Rick86's Avatar
Rick86
whats the dilema 3.75 stroke or 3.800 stroke :confused:
Old Feb 12, 2002 | 06:01 PM
GlockLT4's Avatar
GlockLT4
Default Re: [Poll]: Engine Rebuild Choices (Rick86)
Uhhh.. 3.8" stroke?? I think you mean 3.875 (which is a 396) 3.8 (which oesn't exist to my knowledge), is a 387.70cc
[Modified by Glock'94, 4:03 PM 2/12/2002]
Old Feb 12, 2002 | 06:36 PM
your drinking buddy's Avatar
your drinking buddy
Cruise-In V Veteran
Cruise-In VI Veteran
Default Re: [Poll]: Engine Rebuild Choices (Glock'94)
I wanna build a 396, but I dont think my dad would like me to have that motor :crazy:
Old Feb 12, 2002 | 08:24 PM
AKS Racing's Avatar
AKS Racing
Default Re: [Poll]: Engine Rebuild Choices (vettes rule)
I've done the 383 route and the fully forged 355 route. The last one I completed was the 408 w/ the supercharger. I did this to be different and to make lots of torque/power without twisting it to very high RPM ranges. I would say that for all around ease, the 383 is a much better route. The 408 required lots of work to assemble and then lots more work to get everything right in the car. Now that I've said all that, I am currently in the process of building a much larger cube motor, again in the small block package w/ large blower package (for another vette). Go figure!
It's all in what you are looking to build. I do say this, if you continue to drive it like you have in the past (high mileage), I would stick to a good R/S ratio (like the 383). This will allow the cylinder walls to last longer and stretch the duration between overhauls.
Best of Luck with your decision.
Aaron
Old Feb 13, 2002 | 10:24 AM
dgoodhue's Avatar
dgoodhue
Scat sells them
http://www.flatlanderracing.com/stroker350388a.html
Old Feb 13, 2002 | 03:35 PM
  #33
GlockLT4's Avatar
GlockLT4
Default Re: [Poll]: Engine Rebuild Choices (dgoodhue)
Scat sells them
:eek: :eek: :eek: :eek: Cool, thanks for bringing that to my attention!
Old Feb 13, 2002 | 04:33 PM
  #34
Rick86's Avatar
Rick86
GM's HT383 P/N 12497317 uses 4.00 bore with 3.80 stroke for 383 check out Hot Rod March 2002 ed pg24 :)
Old Feb 14, 2002 | 10:50 PM
  #35
HWoods's Avatar
HWoods
383, with stock ZZ4 cam and AFR 190cc heads. Desk Top Dyno shows this to make some impressive HP and torque, plus it is a simple build up
Old Feb 15, 2002 | 12:17 PM
  #36
ASRoff's Avatar
ASRoff
Default Re: [Poll]: Engine Rebuild Choices (HWoods)
396 I'm a sucker for nostalga. The more cubes you got the more tame that radical cam your going to get will be. I found a 396 kit with a cola crank some oliver rods and srp pistons for $2095 :cheers:
Old Feb 15, 2002 | 06:48 PM
  #37
Mojo's Avatar
Mojo
Default Re: [Poll]: Engine Rebuild Choices (ASRoff)
Having done a 408, I'd go with a 355. The 408 is hard to keep cool. At least it is here in the central valley where the temps regularly hit 100.
To [Poll]: Engine Rebuild Choices
Old Feb 15, 2002 | 10:23 PM
  #38
AKS Racing's Avatar
AKS Racing
Default Re: [Poll]: Engine Rebuild Choices (Mojo)
Was that a 408 using the 0.040 overbore 400 block and a 3.75 stroke crank? Or was it a 4" stroke in a 0.030" overbore 350 block? I have had no issues with cooling on the 350 block version.
Just curious.
Aaron
Old Feb 16, 2002 | 12:26 AM
  #39
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Default Re: [Poll]: Engine Rebuild Choices (AKS Racing)
I thought you were gonna buy a new car? ie Callaway or ZR1
Old Feb 16, 2002 | 01:45 AM
  #40
AKS Racing's Avatar
AKS Racing
Default Re: [Poll]: Engine Rebuild Choices (SurfnSun)
SurfnSun,
You must have me confused with someone else. I have had past experiences with Calloways, and have driven many ZR-1s (never owned one though). But if I were to buy one, it would either be a 96GS roadster (must have red interior), or something like a '02 Yellow (maybe white) MT roadster. Maybe one day. For now, I must just be content with the new engine build-up sans blower and possibly more mods to the '98 roadster LS-1. Already done heads, intake, and cam on the LS-1. Maybe the new LS-1 Procharger would be a good addition. But for now, no new additions to the family. Unless someone knows of a GS as described above ...
Oh, I did buy my wife a new '02 Toyota Sequoia (nearly the cost of a vette) a couple months ago for her B-day. Does that count?
Aaron
