So called 1st run SLP runners?
They have very little restriction in them compared to the SLP 2nd design. With the 2nd design they have bolt lug bosses protruding into the air flow and that cuts down on the cross sectional area. Plus they did away with the siamese on the one runner set.
I have modified mine since then by siamesing the other side and I'm making over 370rwhp with a 355. With my new build I expect to break the 400rwhp barrier but with an increase to 369 cubic inches.
Yes those are very good runners.
Should i fully siamese these?
Mods
1991 TPI stock long block 113 heads
Old style SLP runners gasket matched with Bigmouth intake gaskets.
TPIS Bigmouth intake
Ported plenum with 48mm TB
CC502 cam 218/224 @.050/495/503 lift 112lsa
Bosch III 24# injectors and AFPR
Scorpion 1.5 roller rockers
Flow master cat back and TPIS Ypipe
Whether or not to fully siamese the other side would depend on the desired operating range of your motor. You need to look into wave harmonics.
By the way I consider the last design of the SLP runners to be one of the worst aftermarket runners out of the box. However the good news is they can be modified to your hearts content.
The first design like you have is mostly already there from a modification stand point and requires a lot less work for all out mods.
When you look at HP graphs for TPIs, LT TPIs, SuperRams, HSRs, Minirams, etc.... you'll see how the curve changes as tubes are shortened. As they get shorter than a superram, they essentially take on the character of a short-runner intake.
By having dividers completely removed, you'd have a short-runner intake with long-meaningless tubes on top. The TPI harmonics would be gone because of the length. (And, I'd question if the tubes become a detriment.)
When I calculated the optimal length (for my goals/rpms), I liked anything from the SR length to 2" longer. To me, anything shorter made keeping a TPI pointless. Anything longer meant sticking with ASM's, TPIS big tubes, the FIRST, etc....
Even if you hiding from the CA smog police, having a SR length divider makes the most sense for a street car.
It's all in the wave harmonics vs divider length. (If you'd like to see how the length's work, look at the last few posts of the active FIRST intake thread. Chris posted a link to a runner length calculator.)
Roy
Sorry, for all the questions
I put them on the car when it was bone stock. I didn't port them, but I had to clean up the openings a bunch to make them even halfway round because the castings were so poor.
If memory serves (it's been a long time ago), the car ran out of steam at about 44-4500 stock, and the SLP's extended that maybe 200 RPM. Between the runners, a chip, and Flowmasters, I picked up about 2/10's in the quarter.
I ported my heads and put on an ACCEL base with these runners in 1996 and the car felt choked. I switched to AS&M large tubes and immediately picked up 2-3 tenths and almost 3 mph in the quarter.
I've seen the "new" style SLP runners and the thing I noticed most was that the casting quality was MUCH better. As far as function goes, I don't feel there would be that much difference as cast. I think the older style might offer more performance in a mega-ported state, but IMO the effort to mod them wouldn't be worth the gains over large tubes.
I still have the first-gen SLP's. I'm willing to sell if someone wants them. They are just collecting dust in my attic.
You never mentioned that to me. So you're saying the ASMs were .2 tenths faster than these? (Maybe that's why SLP said we never made those
) I thought your set went to another member. If you still have them, I suspect ekess would be interested in buying them from you.
gp
Geez, Gregg, do you have to debate EVERYTHING???Now, it's hard for me to see that config as being slower than ASM's -- unless the inner tubes are THAT bad. And, I mean horrible.
With my next motor and the same intake system I expect to up the shift point even more. Long live TPI.
That's what I was thinking. Then, a few minutes later, I remembered a comment that MBDiag made recently. It was that the TPI tubes actually lower redline for a 350 block because of the "backpressure" they create (for the bottom end) at higher rpms. That's probably what the other two sets of tubes were doing. Not only weren't they contributing at higher rpms, they actually held it back.
So I answered my own question.
