Is booster push rod adjustable?
Old Jul 4, 2009 | 08:27 AM
Qiken's Avatar
Qiken
Default Is booster push rod adjustable?
while wiping around the push Rod protruding from the Brake Booster prior to installing a new Brake master Cylinder,it turned counterclockwise between quarter and half a turn...have I unscrewed it slightly and need to re-adjust or does it just rotate freely?
Old Jul 4, 2009 | 10:57 AM
joecarter85's Avatar
joecarter85
"The rod on the booster is adjustable and affects where the brake pedal will sit. When I replaced mine, I got lucky because it was already adjusted exactly the same as the old one. Someone will have to chime in on the rod adjustment. "
http://forums.corvetteforum.com/c4-t...e-booster.html
Old Jul 4, 2009 | 11:08 AM
Aardwolf's Avatar
Aardwolf
It's been awhile but from memory it rotates freely. To actually adjust it you need to hold the knurled part and turn the other part.
Old Jul 4, 2009 | 05:05 PM
86PACER's Avatar
86PACER
I did not even know about the adjustment when I replaced mine years ago either. I just bolted it on right out of the box, and luckly the pedal sat fine.
Old Jul 4, 2009 | 09:48 PM
Qiken's Avatar
Qiken
Thats what I thought as I did not touch the knurled lock nut.
To Is booster push rod adjustable?
