Tail light sockets
Old Jul 6, 2009 | 11:09 AM
SwampRat's Avatar
SwampRat
Default Tail light sockets
I picked up a used C4 rear "bumper" at a flea market. I'm going to just hang it up for decoration in the garage. I want to put in the tail lights so that I can flip them on from time to time. No lamp holders were included. Is the lamp holder from a C4 (I'm guessing it's about an 87) interchangeable with other GM models? I'm trying to source the lamp holders and it will be easier if they were a standard part that I could easily find. Any suggestions appreciated.
Old Jul 6, 2009 | 11:17 AM
c4cruiser's Avatar
c4cruiser
The bulb holders are a GM standard socket. Any parts store should have them.
But that requires a 12v source to use them. The tail lamp housing should be flat where the socket is inserted. You might think about gluing a piece of flat plastic to the housing and drill a hole that would accept a small bulb and socket from something like a night light or a socket cut out from a Christmas tree light set. That way you can just plug a cord into a wall socket and add an in-line rotary switch or hide a toggle switch above the license plate opening.
Old Jul 6, 2009 | 11:23 AM
SwampRat's Avatar
SwampRat
I have an old AC to DC power source laying around, so that won't be a problem. Thanks for your input!
Old Jul 6, 2009 | 11:48 AM
Chapindad's Avatar
Chapindad
I would use the new LED lights for it. They have replacements for all the car lights now....
Very cool idea!
Old Jul 6, 2009 | 09:34 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Very cool idea!
I`m going to do that to my actual car. Much cheaper than the L.E.D. complete light sets out there
Old Jul 7, 2009 | 12:33 PM
SwampRat's Avatar
SwampRat
If I were able to find a complete taillight wiring harness, does the wiring end in a positive/negative connection that I could just connect to a DC converter positive/negative, or would that not work?
Old Jul 8, 2009 | 10:48 AM
SwampRat's Avatar
SwampRat
ttt
To Tail light sockets
