Antenna trouble 93 - C4
You'll need to remove the left rear tire and cowling. At that point you can see the antenna.
Now you need to remove the rear hatch deck trim and if I recall, the speaker trim and speaker. This is to get at the antenna connections which you'll unplug.
Next there are a few ground straps near the antenna and the rubber bezel where the mast runs up through the body.
The antenna itself mounts to a bracket with just a couple bolts.
Good luck!
Date Published: 2001-06-08
Submitter's Name: Julian Shipp
Email Address: julianshipp@journalist.com
Corvetteforum.com Member Alias: onedef92
Due to several e-mail inquiries, here are the instructions for removing the power antenna motor for service BEFORE installing a new antenna mast on 1992-1996 Corvettes.
Many owners (myself included) have tried in vain to simply install a new antenna ribbon without inspecting the motor first for broken sections of the old one.
The usual result is an antenna that won't fully raise or retract, even though the motor works fine. Hopefully, this tech tip will save you from this aggravation.
I'm not familiar with the design for 1984 - 1991 models, but the process should be similar. I also understand from other Forum members that the antenna motor design apparently changed in 1995 from housings that are screwed together to housings that are glued together.
If this is the case, it may be possible to pry the assembly apart for inspection. Anyway, here goes:
The power antenna motor is visible from underneath the vehicle if you lie on your back and look at it from the driver's side of your car.
Please protect your eyes from dirt and other particles that may fall from your fender well while you are working! Some Forum members opted to place their vehicles on jack stands and remove the driver's side rear wheel first, but I have long arms and did not have to do so.
1. Disconnect the negative battery terminal. Note the way the motor is oriented as installation is the exact order of removal. The motor is held in place on its mounting bracket by two screws. Use either a socket wrench with an extension or a screwdriver with a ratchet to remove the bolts. Note that one of the bolts has a ground/power wire for the antenna.
2. With these two bolts loosened, you will be able to pull the antenna down toward you enough to loosen the antenna gain and positive power wires located at the top of the unit. With all these wires removed, the entire assembly can be pulled down for access while leaving the wire that lead inside the motor housing intact.
3. With the unit now in your hand, roll up the black rubber sleeve that protects the unit from moisture, dirt, etc. There are approximately four Phillips head screws that hold the cover on the motor housing. Remove these screws. Also, remove the center nut that holds the antenna flywheel in place. With the cover off, you will see the flywheel and the main gear that raises and lowers the nylon antenna ribbon. You will also more than likely find bits or long sections of your OLD ribbon. Remove them.
4. Now is the time to lubricate the main gear and flywheel with either Vaseline or white lithium grease to ensure years of trouble-free operation with your new ribbon.
5. Replace the flywheel (noting its direction) and screw the cover back into place. Re-install the antenna, connect all the wiring and hook your battery back up. Turn on the ignition and radio and listen to see if the motor runs. If it does, you are ready to install your new mast. Just follow the directions that came with it and you should be in great shape.
6. Above all, be patient. It took me about four hours the first time I did this because I thought you had to remove the license plate, tail lamps and back up lamps to get to the motor. You don't! I could now do the whole thing again in 30 to 40 minutes (but hopefully not on MY LT-1 any time soon!) Good luck and keep on waving!
1992 LT-1 Corvette Coupe, Dark Red Metallic on black leather interior, auto, Z-51, FX-3 suspension. 121,0000 miles, Stock...for now. julianshipp@journalist.com
http://forums.corvetteforum.com/c4-p...a-92-96-a.html
Thanks again to all for their help. You are truly a GREAT group.
I did the exact same repair couple years ago. Just wanted to add some information and pictures from then so all could see what was involved.
http://forums.corvetteforum.com/c4-g...y-surgery.html
And, you can get the replacement mast and ribbon from your Chevy dealer.
About $28.
Thanks to all.
Also, check the connection where the antenna wiring goes into the motor housing.
If you DO opt to purchase the entire motor, make sure it's the O.E.M. Delco or Harada unit (depending on your year) so you won't have any issues with the stock wiring and reception connectors.
Just trying to save you a few bucks. It's pretty easy to replace the mast, read the replacement instructions I wrote in this thread.
