L98 Distributor Issues
Old Jul 14, 2009 | 05:30 PM
CaminoSS's Avatar
CaminoSS
Default L98 Distributor Issues
Okay here goes. 90 auto. Changed injectors and had an oring spilt. Little fire when the gas ran down the back. Got it out. Now the bad. Some wires cooked. No biggie. Re-wired and things ran okay but car stumbled and spit and sputtered at wide open throttle and higher rpms.
To add to it, the car failed emissions.
I opened the distributor up and the plastic housings for the wiring were all brittle and broken. Tried to clean up the mess and afterwards no start.
Got a new distributor from O'Rielly's. Installed with a new cap, rotor, and coil. Coil is recievign power, but no crank. Not even a little try at it. Engine just turns over.
The wire harness that goes from the 4 pin plug for the ECM to the modual is one of the ones that came apart. I am not sure of the sequence for the wires to the modual. And getting another harness/pigtail takes about 5-7 days for my local Chevy dealership to get. The other parts houses can't get it.
Suggestions? Is this why I can not get spark and crank? Wiring order?
Thanks guys.
Old Jul 14, 2009 | 10:02 PM
rodj's Avatar
rodj
Originally Posted by CaminoSS
. Coil is recievign power, but no crank. Not even a little try at it. Engine just turns over. .
Battery undercharged / flat
Bad connections /ground between battery and starter.
If your battery is low when cranking it wil take all the power leaving nothing for the spark as well as engine not spining fast enough tp catch
Old Jul 14, 2009 | 10:52 PM
Muffin's Avatar
Muffin
Good luck on buying a new wiring harness. Local Chevy dealer wanted $125.00 for a new one. No mistake,$125.00.
Old Jul 15, 2009 | 12:53 AM
engle1147's Avatar
engle1147
If the wires are mixed up on the ignition module because they were baked and missing insulation then wait for the new pig tail harness to arrive before trouble shooting it further....the ignition miss wire situation could cause your no start condition. Glad to hear the fire was controlable.
Old Jul 15, 2009 | 06:02 AM
rodj's Avatar
rodj
but no crank. Engine just turns over.
Is the engine turning over not cranking???
Does it crank over or not? Is what you have a "no fire" situation?
Distributor Connector, TPI Large Cap HEI
Plug and pigtail here $11
http://tpiparts.net/inc/sdetail/1847
Or EFI Connection
www.eficonnection.com (away for this week
Old Jul 15, 2009 | 08:16 AM
LD85's Avatar
LD85
I believe, the fuel pump gets a signal through the wires to the distributor as well, so if there is an intermittent connection, the fuel pump could be cutting out.
Correct me if I am wrong, I have not messed with mine for quite some time.
Old Jul 15, 2009 | 11:46 AM
josephf31's Avatar
josephf31
Default Firing order
Thanks guys.
Is 1 8 4 3 6 5 7 2
Memorized those when I was like 12 (looooong time ago LOL)
Old Jul 15, 2009 | 05:24 PM
CaminoSS's Avatar
CaminoSS
Or EFI Connection
Engine turns over but no crank or spark hitting the plugs.
Thanks guys
Old Jul 16, 2009 | 04:50 PM
Chapindad's Avatar
Chapindad
Did you get the ignition module tested? If I could get my hood open I would go out tonight and get you some pictures. If nothing is posted to help you by this weekend then I will get that darn hood open and get those pictures for you.
Old Jul 17, 2009 | 12:52 AM
arrested609's Avatar
arrested609
Had the same promblem with mine. I plugged the ignition module wrong. i was getting no fire to the spark plugs. Good luck.
To L98 Distributor Issues
