Fuel Rail Questions
Old Feb 13, 2002 | 02:29 PM
Guest
Guest
Posts: n/a
Default Fuel Rail Questions
Hi, 2 questions for everyone, are all the tpi fuel rails the same? like is a 305 camaro flow the same as the L98 one? also anyone know who makes a fitting so i can mount a fuel press sender on the fuel rail? thanks......... :chevy
Old Feb 14, 2002 | 12:50 AM
Vic'89's Avatar
Vic'89
Default Re: Fuel Rail Questions (Kamarossrs)
The Camaro and Vette fuel rails are different lengths.
Vic
Old Feb 14, 2002 | 10:19 AM
vettedan's Avatar
vettedan
Here my set up for an LT1. I had to weld a AN fitting on the input side.
Dan
Old Feb 14, 2002 | 11:36 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Though slightly different in phylical form, the function and fuel pressure of the LB9 fuel system is similar that of the L98; the LB9 uses 19 lb/hr injectors vs the 22 lb/hr of the L98. Both systems have an FPR at the rear and a Schraeder valve on top of the right side of the rail and use plenum vacuum to control fuel pressure via the FPR.
Old Feb 14, 2002 | 12:16 PM
Jim85IROC's Avatar
Jim85IROC
Default Re: Fuel Rail Questions (65Z01)
I don't believe that the LB9 and L98 rails are different in any way other than what size injector they feed.
I do know that the f-body rails get fed fuel through the front instead of at the rear like the y-body rails.
To Fuel Rail Questions
