C4 Engine Pull
Old Jul 19, 2009 | 10:28 PM
Tevroc98's Avatar
Tevroc98
Default C4 Engine Pull
What's the easiest method to pull the motor out of a C4? Take the front Clip off or from underneath? Any help would be appreciated.
Old Jul 19, 2009 | 10:34 PM
Calderone's Avatar
Calderone
i had to tie it up with seatbelts ! call me wild i did it almost on the street
Old Jul 19, 2009 | 11:34 PM
hip's Avatar
hip
Default pulling C4 engine
The easiest & quickest way to pull C4 engine is to remove hood prop & pull from the side. Remove the damper pulley & wiper motor, dist, exhaust, converter bolts, trans bolts. Mark your wires & cables, don't forget your ground cables on left head. Its not a hard job maybe 2 hrs.
Old Jul 19, 2009 | 11:38 PM
jimg's'93's Avatar
jimg's'93
2 hours? Maybe after you've done it a time or 2.
Old Jul 20, 2009 | 12:12 AM
scorp508's Avatar
scorp508
It isn't bad. It's a lot easier without the bellhousing on for a stick car. I've done mine from the passenger side with the hood still on and had plenty of clearance. The hoist's legs slid perfectly on either side of the wheel.
Old Jul 20, 2009 | 12:21 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Happy Hooker and jack-crane
Old Jul 20, 2009 | 12:25 AM
twin540's Avatar
twin540
If you've never pulled a motor before it might be easier if you take the intake and head off if you don't want to pull hood etc.
Old Jul 20, 2009 | 04:51 PM
ScaryFast's Avatar
ScaryFast
I like to pull the motor and trans together (6-speed). It's easier than separating them on the car IMO, but you will need a second person to help guide the motor out and back in.
I also remove the hood and pull from the front. It's only 4 bolts, I don't know why everyone tries to do it with the hood on.
I've done it several times and I think 2 hrs is a bit aggressive...unless you're not counting hooking up all the wiring and hoses in that time.
Old Jul 20, 2009 | 05:19 PM
93 ragtop's Avatar
93 ragtop
Do you leave the radiator in the car or do you need to pull it. I have read where all accessories and radiator can be left on when removing the transmission first.
Old Jul 20, 2009 | 05:26 PM
PLRX's Avatar
PLRX
2017 C4 of Year
I removed the engine with the hood on. It was not on my way, the tire was though.
I'm thinking about putting the engine back with the bellhousing etc. But with the tranny attached, I'd like to see pictures.
Old Jul 20, 2009 | 05:41 PM
TravisD's Avatar
TravisD
Pulling the trans+flywheel first and using the TPIS "Happy Hooker" makes it a one-person job. AC Compressor gets laid over to the side, radiator/fans stay in place.
Old Jul 20, 2009 | 06:02 PM
bdw18_123's Avatar
bdw18_123
From: Prather, California -1990 ZR-1 White/Flame Red- -SOLD!!-
I pulled the LT1 in my '93 ZF6 with the hood on and bellhousing attached. But I had to remove the motor mounts, then lower the engine even lower to get some room to get to the top 2 tranny bolts. I left the ZF6 installed. I think most people don't want to remove the hood because it's heavy & bulky and hard to get re-aligned.
When I pulled the LT5 out of my '90 ZR-1, I couldn't leave the bellhousing on because it was too long. So I had to removed the ZF6 completely, remove the bellhousing, then pull the engine. All this was with the hood on.
Old Jul 20, 2009 | 06:45 PM
aboatguy's Avatar
aboatguy
+1 happy hooker from side with hood on, and leave engine intact
works with my Long tubes too.
I never have to mess with hood, AC or radiator.
I can have whole engine sitting on garage floor or engine stand in less time than it used to take me to remove headers and intake (on plain old remove short block pull)
No joke it is so quick to pull and reinstall engine I'm tempted to pull the engine when its time to change plugs.
Old Jul 20, 2009 | 11:08 PM
hip's Avatar
hip
Default pulling engine
You are right about the 2 hrs. to pull, I've had my '84 for about 12 yrs I've had 12 diffrent engines in it the last 5 yrs. allways pulled from left side.maybe 3 hrs. working not playing around. I have never tried to leave headers on. My cherry picker has an adjustable weight leveling bar, crane or whatever you call the piece that makes a big diffrence in pulling, no droping back down to readjust chain. just turn handle on bar to adjust. I have had engines from modified crossfire, to 427 SB & enjoy this C4 more than my C5. good luck with your pulling, an extra pair of hands are handy
Old Jul 21, 2009 | 10:10 AM
ScaryFast's Avatar
ScaryFast
Radiator stays in, accessories stay on except the PS pump. I have LT headers so I take them off. It makes things easy if you remove the passenger side brace, but it's not required.
I don't have pictures of the install or removal, just lots of pics of the motor out of the car and the car with no motor. BAsically, one guy runs the cherry picker, the other guy goes between the firewall and under the car to jack up the trans as you slide the motor in.
Old Jul 21, 2009 | 11:08 PM
aboatguy's Avatar
aboatguy
If you have EM long tubes try leaving them on.
I honestly thought that I could not pull it with the EM LTs but to my surprise it worked and leaving the headers on makes a 2 hour engine pull within the realm of possiblity
Mike
Old Jul 22, 2009 | 12:13 AM
96GS#007's Avatar
96GS#007
Another vote for a fully dressed engine from the side (with the Happy Hooker!)
To C4 Engine Pull
Old Jul 22, 2009 | 04:55 PM
LBYRNES's Avatar
LBYRNES
I have a stock '93 LT-1. I:
- left the hood on.
- Flipped the A/C to the side.
- Flipped the Fuel Rails to the other side.
- Unbolted that Automatic Trans.
- Removed the exhaust system.
- Loosened the C-Beam so that I could lower the trany with a small jack, so that I could get at the top two bolts.
- Used a happy Hooker and all went well.
Old Jul 23, 2009 | 07:32 AM
LD85's Avatar
LD85
Leaving the headers on? not with hooker 2151's, they obstruct the motor mount bolt, so on my car the headers can not be on.
Old Jul 23, 2009 | 07:53 AM
TravisD's Avatar
TravisD
Which bolts are you referring to? When I pulled mine, the mounts stayed on the block, just the large single nut that goes thru the diagonal brace got pulled. It *should* be a straight shot from under the car, even with headers I would imagine.
