89 timing procedure
Old Jul 21, 2009 | 05:23 AM
GS023's Avatar
GS023
Default 89 timing procedure
Anyone have a procedure for setting intial timing on and 89? New motor with MSD distributor.
Old Jul 21, 2009 | 10:45 AM
engle1147's Avatar
engle1147
If the distributor as been installed correctly simply disconnect the ESC connector and use your timing light while someone else cranks the starter to ensure that it is between 4 - 6 BTDC. You may have to goose the throttle to get the car to idle/start. Reconnect the ESC connector to restore the advance. If you messed with the IAC you may need to do a "reset " if you have "hunting" idle issues.
