Plastic Top
Old Jul 21, 2009 | 11:37 PM
Schooner32's Avatar
Schooner32
Cruising
Default Plastic Top
Need to glue the metal edging around the plastic top. What type of adhesive should I use? I know some types don't agree with the plastic.
Thanks, Don S.
Old Jul 22, 2009 | 12:05 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
You need to be more specific.
What metal edging?
Pictures
Year of Vette, location parts etc.
Old Jul 22, 2009 | 09:55 AM
Schooner32's Avatar
Schooner32
Cruising
Default Plastic Top
It is the plastic removalble roof panel and it has metal edging around 3 side of it. It has came loose and needs to be reglued.
Its a 1986 but don't know if panel is from that year. I'm sure that it takes a special type of adhesive to attach this.
Thank you, Don S.
Old Jul 22, 2009 | 02:04 PM
josephf31's Avatar
josephf31
Default If
Thanks, Don S.
the acrylic is delaminating from the frame, don't do it. The glue will come off eventually and the top could fly off while you are driving, causing serious damage to someone, you don't want that.
Melrose will reglue the top properly if you send it to them, otherwise you are taking a big risk. Just my opinion ;-)
Old Jul 22, 2009 | 09:41 PM
Schooner32's Avatar
Schooner32
Cruising
Default Plastic Top
It is not the frame of the acrylic that holds it to the body. It is a metal extrusion ( u shape to fit over the edge of the acrylic--3/8" by1/2") it fits around the front and both sides. Maybe I an the only one who has this type of top.
Thanks, Don S.
To Plastic Top
