Does yours vibrate
Old Feb 24, 2002 | 04:31 PM
  #41
Dualnic's Avatar
Dualnic
Default Re: Does yours vibrate (Glock'94)
Hey guys, I bought this lifetime alignment from Firestone for about $150. It is good for the rest of your ownership of your car. Do they realize how often I will be in there for a balance???
I could not pass up on that deal....got the whole package when i mounted my new wheels/tires about 2 yrs ago...(Lifetime Balance/Rotation) and (Lifetime Alignment)
Every 5k -10k i am there :) No Charge!!!!
I almost forgot......"NO Vibrations any speed."
[Modified by Dualnic, 2:36 PM 2/24/2002]
Old Feb 24, 2002 | 10:39 PM
  #42
Borton's Avatar
Borton
Default Re: Does yours vibrate (thedevl)
Yes, my 90 convertable with automatic trans and vin code 8 engine vibrates. A better description would be the car shudders when
lightly accellerating from speeds from around 35 to 45mph.
The shudder feels like the engine and trans are hopping up and down. Can be avoided by accellerating a little harder.
Don't have a fix. Would like to know how to solve this one. Any ideas?
Old Feb 25, 2002 | 12:00 PM
  #43
thedevl's Avatar
thedevl
Default Re: Does yours vibrate (Borton)
Borton:
Sounds like your is a different problem, ours vibrates no what at about the same speed for all the cars.
Flynn :reddevil
Old Feb 25, 2002 | 05:27 PM
  #44
96LT1's Avatar
96LT1
Neither the '86 with 128,000+ or the '96 with 55,000+ vibrate. I've had both cars up 120+ (on the track). I replaced the entire front end on the '86 last winter due to wear. The ball joints, tie rods and bushings were all starting to go. Considering how worn the parts were, I was surprised it didn't vibrate.
Old Feb 25, 2002 | 05:43 PM
  #45
Black87c4's Avatar
Black87c4
Default Re: Does yours vibrate (96LT1)
Mine does at 70-75 as well, I can feel it in the steering wheel.
Old Feb 25, 2002 | 09:24 PM
  #46
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
Default Re: Does yours vibrate (Black87c4)
Mine shakes starting from 50 mph onwards. It's driving me nuts!! :mad :mad :mad I'm running out of places to fix...
Old Feb 26, 2002 | 10:39 AM
  #47
thedevl's Avatar
thedevl
Default Re: Does yours vibrate (CoolVette86)
I hope to get my balanced drive shaft re-installed this evening if all goes well. The flu is leaving me slowly and I am feeling better. Hope the drive shaft changes something, even if it doesn't fix it, if it changes the characteristics, I would be encouraged.
Flynn :reddevil
Old Feb 26, 2002 | 11:01 AM
  #48
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
I'm sure this has been said already, but check your ujoints. Mine started vibrating in the fall and got progressively worse. I just had my ujoints changed (one of them was clicking, but I went ahead and had all 4 on the half-shafts replaced) and it solved the problem completely.
Old Feb 26, 2002 | 12:15 PM
  #49
thedevl's Avatar
thedevl
Default Re: Does yours vibrate (EvanLT1)
EvanLT1
If you click on the link below, it will take you to a thread where you will see what all has been done. This has been an exhaustive effort. Everything anyone could think of has been tried, except for rear end gears.
Flynn :reddevil http://forums.corvetteforum.com/zerothread?id=234718
[Modified by thedevl, 8:19 AM 2/26/2002]
Old Feb 27, 2002 | 10:35 AM
  #50
thedevl's Avatar
thedevl
Balanced drive shaft went in last night. Need to bleed brakes from doing brake job on all four corvers while I have the car down for u-joints all around, wheel bearings and DS balance. Will test tonight.
Flynn :reddevil
Old Feb 28, 2002 | 10:48 AM
  #51
thedevl's Avatar
thedevl
It is fixed. The balanced,straightened driveshaft with the new u-joints fixed the problem. The shaft was warped and bad out of balance and the u-joints felt a little notchy. My corvette no longer vibrates at 75MPH. Too cool.
Flynn :reddevil
Old Feb 28, 2002 | 11:20 AM
  #52
lcvette's Avatar
lcvette
Default Re: Does yours vibrate (Knight Ryder)
yes my LT1 vibrates at about 70-78 mph but its only there for about 1-2/10's of a second and then its smooth as babies butt.. and feels alot like gliding at 150+ :D good luck.. i believe my issue to be in wheel balancing.. i have found that as ugly as the outside balance weight are.. they usually do a better job.. but i will accept the vibration and stick to my stickon inside the rim weight to preserve my A-molds appearance!!
chris
[Modified by lcvette, 9:21 AM 2/28/2002]
Old Mar 4, 2002 | 11:01 AM
  #53
thedevl's Avatar
thedevl
Default Re: Does yours vibrate (lcvette)
Checked it out further over the weekend and this thing no longer vibrates. Drive shaft issues were solved and the vibration went away.
Flynn :reddevil
Old Mar 5, 2002 | 01:28 PM
  #54
GiDvEtTe84's Avatar
GiDvEtTe84
Mine used to. I changed the back tires, had all tires rebalanced, and aligned. Then it stopped. :smash:
