Programming o2 open loop?
Old Jul 26, 2009 | 10:47 PM
-=Tom=-'s Avatar
-=Tom=-
Default Programming o2 open loop?
Hey guys is there any way to program the PCM on my 95 for an open loop type of tune? For example setting on mixture for idle and another for anything other than idle and WOT?
The reason I'm asking is to try and narrow down a problem I'm having as NOT being o2 sensor related. If I can make a setting change in tunercat to disable or bypass the o2 sensors then I'll know if it's an o2 issue.
Thanks.
Old Jul 27, 2009 | 02:14 PM
bjankuski's Avatar
bjankuski
Thanks.
Raise your closed loop temperature to the max amount so the car never goes into closed loop.
Old Jul 28, 2009 | 09:23 AM
-=Tom=-'s Avatar
-=Tom=-
Thanks! I hadn't thought of that. So simple too.
To Programming o2 open loop?
