Relay ID?
Old Jul 28, 2009 | 09:19 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default Relay ID?
Can you guys tell me what this relay is? It is located on the left front inner wheel well in front of the battery area.
Old Jul 28, 2009 | 09:25 AM
rodj's Avatar
rodj
Main fan ?
The burnoff relays are side by side in the same area and the TCC and fuel pump are on the firewall
Old Jul 28, 2009 | 09:46 AM
engle1147's Avatar
engle1147
Originally Posted by rodj
Main fan
Old Jul 28, 2009 | 11:55 AM
floridamale's Avatar
floridamale
Just call Chevy you have the number a lot of the same relays service different things they should be able to tell you what it's for
Old Jul 28, 2009 | 03:18 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Originally Posted by engle1147
Old Jul 28, 2009 | 08:34 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Main fan ?
Local GM parts guy finally got back to me and you guys are right, as usual. Its the main fan relay. The part number is still good and I was able to order one from somewhere in the GM network in West Virginia @ $13. Should get it in the next few days.
Thanks much
Old Jul 28, 2009 | 10:40 PM
Muffin's Avatar
Muffin
Relays dang near never go bad. Are you sure your problem is the relay? Reason I ask, last weekend out for a drive, shocked by high temps that fell with a little speed. Fan wasn't coming on. Once home and cool I found a broken wire on the relay plug. A little solder and shrink tubing and we were cruzin again.
Old Jul 28, 2009 | 11:11 PM
rodj's Avatar
rodj
No but those crappy early style non weatherpak connectors do.
I swapped mine out for the weatherpak connector / relays because nearly all had lost the insulation on the wires causing, in the case of my fuel pump a intermitent short on rough roads.
Old Jul 28, 2009 | 11:58 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Relays fail in different ways.
1. burned contacts
2. worn pivots
3. overheated contact supports
4. open circuit in coil
5. short in coil
6. loose contacts
7. overheated connector pins/ sockets/blades
8. distorted cases due to heat and misaligned contact arms
Relays are often under engineered, over rated, and overloaded.
relays have many characteristics that dictate their design shortcomings including physical size, wire sizes, location space.
Most relays are sealed, and some are sealed but have a vent to assist in bleeding off gas pressure and ozone, but let in humidity.
just for starters
Old Jul 29, 2009 | 01:15 AM
pologreen1's Avatar
pologreen1
LOL wow I just took that out of my dads today, it was over heating, so I checked it, and it was bad. $15 for him to fix and sell the car.
Old Jul 29, 2009 | 07:50 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
GM parts direct stocks it for $9.74.
http://www.gmpartsdirect.com/catalog...TOKEN=11382399
Old Jul 29, 2009 | 09:26 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Actually, the relay is working fine. However, if you look at the photo closely, you will see where I accidently snapped off the connector hold-down bar from the front of the relay housing. As the wire harness connection snaps in from the bottom, I am afraid that without the hold-down bar in place, the connector might jar loose when going over rough roads or bumps. Sooooooo, I am going to replace it.
Thanks again for all the great feedback.
P.
Old Jul 29, 2009 | 03:25 PM
nutz4c4's Avatar
nutz4c4
1. burned contacts
2. worn pivots
5. short in coil
6. loose contacts
just for starters
Old Jul 29, 2009 | 04:10 PM
floridamale
P.
They fit in tight but nothing wrong with getting a new one
To Relay ID?
