Too much heat
Old Jul 30, 2009 | 01:52 PM
Doc Savage46's Avatar
Doc Savage46
6th Gear
Default Too much heat
I hope someone can help. I have an 88 with 75k miles on it, runs great except the heat won't quit. I have electronic control on the ac but it's stuck on 90 degrees. I press the cool button, nothing happens, Off button, nothing. no matter what it stays on 90. In the manual it says press the cool button & the temp will go down gradually to 60 degrees and stay there but it won't. Anyone have any ideas, it's getting warm in here.
Old Jul 30, 2009 | 02:52 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Pull the heater hoses off at the firewall and do a heater bypass by connecting them with a straight through coupler. No hot water, no heat.
Old Jul 30, 2009 | 03:00 PM
Doc Savage46
6th Gear
Thanks I'll give that a try.
Old Jul 30, 2009 | 03:26 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
My controls went funky, so I pulled the unit apart and cleaned the connections. It's been flawless for the last 5 years, knock on wood !!
Check this thread out, it has pics
http://forums.corvetteforum.com/c4-t...-for-88-a.html
Old Jul 30, 2009 | 03:28 PM
AGENT 86's Avatar
AGENT 86
Here's some insight from my FSM
http://members.shaw.ca/dankai/HVAV'S.pdf
http://members.shaw.ca/dankai/HVAC%20Electrical.pdf
To Too much heat
