I just bought my first vette about 2 months ago. It is a 94 6 speed with 40K original miles. At 34,704 miles the previous owner had the engine rebuilt with the following:
383 eagle stroker assembly, ported and polished heads and manifold, hot cam, and 1.6 rr
The owner supplied all paperwork for the parts and labor and included a dyno printout. The printout shows max hp as 313 and max tq as 339.
I love the car as it is incredibly clean but the power seems low for the mods. What do you guys think????
It is at the wheels. Guess he could have pulled a fast one. But it sure seems like a lot of paperwork. I got invoices from Summit and from the shop showing vin numbers. Maybe poor tuning or no tuning.
IMO you will never see 450 RWHP, 383 and hotcam in the same sentence.
Most importantly top end makes most of the power (heads/cam/intake etc) so a 383 with same mediocre top end may not make any more HP than a 350 the difference will be that the power will be made at a lower RPM
....and if many times ported (modified) heads are installed on a short block built by a normal SBC guy engine end up with less compression than stock due to a larger combustion chamber. LT1s love compression. (mines a RCH more than 12 to one and runs on pump gas without detonation or knock retard)
a 383 may make 20 more hp but a hot cam is quite a small cam for a 383.. with the stock exhaust i would imagine that is where your hp is being choked out..
