Meet the dumbass
Old Aug 1, 2009 | 08:52 AM
rodj's Avatar
rodj
Default Meet the dumbass
Did you hear the one about;
While chasing a cranking no injector pulse problem , decided to check TPS V. Low TPS at WOT.
No problem, grab another TB off the shelf, plug it in; 4.5V.
Swap over TPS, check with scanner , still low
Check throttle travel and find some dumby (me) in haste to get car running late at night before track day has positioned the hose clamp on TB bellows so it acts as a very efficent throttle stop at 3/4 travel. Been like that for at least 6 months.
Problem went unnoticed because 1st time out was with new 383 engine , 2nd time was with new convertor so no benchmark to judge by. Also both times distracted by spark problem with small cap dist / remote coil setup needed with HSR.
12.2 on 3/4 throttle ; looking forward to next strip outing.
Old Aug 1, 2009 | 08:55 AM
Aurora40's Avatar
Aurora40
LOL! At least no harm was done.
Old Aug 1, 2009 | 10:47 AM
ch@0s's Avatar
ch@0s
Welcome to the Dumbazz club! Please pm me your address so I can send you a packet and a cool bumper sticker.
Thanks, Ch@0s
Dumbazz club President
Old Aug 1, 2009 | 11:28 AM
engle1147's Avatar
engle1147
Thanks, Ch@0s
Welcome!
No membership fee required: http://forums.corvetteforum.com/grou...a-dumbass.html
Old Aug 1, 2009 | 02:50 PM
redrose's Avatar
redrose
"theory" sez a butterfly valve does most of it's throttling in the last few degrees of closing... that last 1/4 throttle may not gain much...we saw numerous carb throttle plates that opened way beyond 90* while dyno test on snowmobile race engines that lost nothing vs limited to 90*...do tell what the effect is on your 'big end" numbers
Old Aug 1, 2009 | 03:14 PM
Weav's Vet's Avatar
Weav's Vet
It happens rodj......did you know you can't bleed your brake calipers with the bleeder screw on the bottom.......
Glad you discovered it!
Old Aug 1, 2009 | 04:13 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
For all those that want a governor for when the kids use the vette, see Rod's new product.
Old Aug 1, 2009 | 06:52 PM
pologreen1's Avatar
pologreen1
wow that bandaid lasted 6 months, good work
Old Aug 1, 2009 | 07:31 PM
1985 Corvette's Avatar
1985 Corvette
hose clamp mod > zip tie mod
Old Aug 1, 2009 | 08:33 PM
pr0zac's Avatar
pr0zac
what was your mph??
Old Aug 1, 2009 | 09:13 PM
rodj's Avatar
rodj
Originally Posted by pr0zac
what was your mph??
110mph But my mph figures alway seem low compared to others running similar ET's.
Back to back test; only change was 3k stall.
383 HSR 2K ;12.309 / 108mph.1.750
with 3K 12.289 /110mph. 1.740
But had above mentioned spark problem with 3K stall runs.
6500 1st , 5500 2nd, struggled to make 4500 in top because coil was breaking down.
Optimistic because I picked up .1 in the 330 and nearly the same at 660 before engine flatlined but still ran best ever mph
Old Aug 1, 2009 | 09:28 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
I'd look at it as an automatic break-in assist device.
Now you're ready to rock.
Old Aug 1, 2009 | 09:34 PM
Demonic85's Avatar
Demonic85
wont work if you've got a C5/C6 though. fly by wire.
Old Aug 1, 2009 | 09:46 PM
pr0zac's Avatar
pr0zac
its looks like you are hooking out of the hole.. the 110 isn't too far off to be honest for that e.t. but you will probably pick up both et and mph without said ignition issues. i don't know what your exact engine setup is aside from whats in your profile but those are decent numbers for a street sbc regardless.
Old Aug 2, 2009 | 09:16 AM
84camino406's Avatar
84camino406
yep. mine runs 12.09 at 109.6
Old Aug 2, 2009 | 11:33 AM
pr0zac's Avatar
pr0zac
lol.. my was a 12.7 @ 111.9
To Meet the dumbass
