changing D36 center section only?
Old Aug 3, 2009 | 12:40 PM
mikemiller68gs's Avatar
mikemiller68gs
Default changing D36 center section only?
I have a 93 with the 2.59 gears. I picked up a used 3.07 center section. Can I change the center section while leaving the batwing, spring, etc in the car? Thank you in advance for the help.
Mike
Old Aug 3, 2009 | 01:35 PM
toptechx6's Avatar
toptechx6
Mike
It is easier to pull the batwing, only two more bolts and it will be way easier to reseal on the bench.
Old Aug 3, 2009 | 01:55 PM
M. Schumacher's Avatar
M. Schumacher
I was thinking along the same lines before I changed mine last month, and I would have to concur. The batwing goes in and out easily, there's no reason not to pull it all. Plus while it's out you have a chance to do the poly bushings.
Old Aug 3, 2009 | 07:24 PM
92ZR1WANNABE's Avatar
92ZR1WANNABE
Drop it all , don't be afraid of that rear spring as its not near as scary as it first looks.
Old Aug 3, 2009 | 08:50 PM
rodj's Avatar
rodj
http://forums.corvetteforum.com/1555394901-post3.html
Old Aug 3, 2009 | 10:11 PM
aminnich's Avatar
aminnich
Do you know all of the steps and procedures?
Old Aug 3, 2009 | 11:06 PM
mikemiller68gs
I've read some posts, an article and I have a FSM. I have changed plenty of 10 / 12 bolt A / F body rears, but this is the first IRS. When looking at the center section I bought, I thought that possibly I could just change it and make quick work of it.
Mike
Old Aug 4, 2009 | 01:29 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
I've done both ways, and it was way faster, and easier to drop the batwing.
To changing D36 center section only?
