Heat and AC Controls...
Old Aug 3, 2009 | 10:52 PM
seijack's Avatar
seijack
Default Heat and AC Controls...
Hello All,
In the past few months I have been having spuratic problems with my heat and AC controls. This morning on the way to work I tried to raise the temperature to give me some heat. I could lower the temp but I could not raise it at all. The on\off and fan controls would work but nothing else....When I got in it to come home this afternoon everything was fine...I could raise and lower the temp and everything worked as it should.....What gives?? Anyone else had this problem?
Thanks In Advance
Old Aug 4, 2009 | 08:42 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You've got a '94 right? First, check the plastic check valve under your fuel rail cover. I think it's on the passenger side. It could be cracked, resulting in a vacuum leak in the climate control unit. I believe it shares the same line that enables your cruise control module, too.
Old Aug 4, 2009 | 08:59 AM
runner140*'s Avatar
runner140*
It is under the right/passenger side fuel rail cover and looks like this:
and sells for under $5.00.
Old Aug 4, 2009 | 10:02 PM
seijack's Avatar
seijack
Originally Posted by runner140*
It is under the right/passenger side and looks like this:
Yes I have a 1994....I did some checking in the service manual and all of the vacume doors seem to be operating in the correct fashion. Does this part affect the vacume doors or does it have something to do with the climate control temp some how....As I said....I can lower the temp of the climate control say down to 60 deg...But I am unable to raise the temp selection up to 85-90 to get some heat.....Who would have
thought I would need HEAT in JULY!!!! I will check this part.. My cruise works great..
Old Aug 5, 2009 | 09:10 AM
pcolt94's Avatar
pcolt94
Originally Posted by seijack
Hello All,
In no way is this the 3 way check valve causing your problem. I have had my own similar problems the last few weeks and have done extensive work on the system and not done yet or ready to post my own results.
Here is a brief summery of how things works. The head sends input to the controller which then operates the vents and the temperature door motor. The temperature door is what controls the air temperature coming in to the (system) car. The problem is you are not able to control the temperature door motor. But it sounds like your main problem is your control head is not working correctly. You should be able to run the temperature up to 90* regardless of anything else. If you can’t control the “head”, then you can’t control the controller or the door motor.
Inside the head is 2 boards that are joined by a multi-pin connector. You might try to disassemble unit and clean the pins as well as the pins on the rear of the unit with alcohol. Always dry things well before re-assembly. Other that that the head might just be defective. If that is the case it might have to be replaced.
Old Aug 5, 2009 | 08:48 PM
seijack's Avatar
seijack
Thanks Guys
I will have to look into the connection in the back and do some cleaning on the electrical connections.
Old Aug 12, 2009 | 08:35 PM
Disneylandguy's Avatar
Disneylandguy
3rd Gear
Thanks Guys
Can someone give me a more clear description of where to find the check valve pictured above. Thanks
Old Aug 12, 2009 | 08:53 PM
rodj's Avatar
rodj
If you can’t control the “head”, then you can’t control the controller or the door motor.Inside the head is 2 boards that are joined by a multi-pin connector. You might try to disassemble unit and clean the pins as well as the pins on the rear of the unit with alcohol..
Many have has success by removing the rubber button pad and cleaning the contacts underneath with alcohol
Old Aug 13, 2009 | 07:59 AM
runner140*'s Avatar
runner140*
The check valve is found under the right side fuel rail cover. OR it can be purchased at any auto parts store for under $5.00 (one minute install)
Old Aug 13, 2009 | 11:17 AM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
What and where exactly is this "control head"?
Same question re the "rubber button pad".
Old Aug 13, 2009 | 11:29 AM
josephf31's Avatar
josephf31
Default Might
also be on the left side, depending on the year/model and previous "mechanics'" work...
Old Aug 13, 2009 | 11:53 AM
pcolt94's Avatar
pcolt94
It's the unit that you control and set with the buttons on it above the radio. Such as fan speed and temperature, that is the control head.
The controller is up underneath kind of above the gas pedal where you can’t see it. I agree the terms are confusing, GM should have completely different names for the units.
RODJ – Also has a good added suggestion for that problem (that I forgot). You do have to take apart the unit to get to clean the buttons.
Old Aug 13, 2009 | 01:14 PM
rementis's Avatar
rementis
I had problems with those buttons also.
This was the cure:
Take the controller out of the dash. Take it apart (just some screws), and find the rubber pad that sits under the buttons. Under that rubber pad there are electrical contacts. I cleaned those by dipping a pencil eraser in alcohol and kind of scrubbing them. You won't really see any difference, it won't look any cleaner. I put it all back together and the buttons all work perfectly again.
Old Aug 13, 2009 | 06:09 PM
92ragtop's Avatar
92ragtop
The controller is up underneath kind of above the gas pedal where you can’t see it. I agree the terms are confusing, GM should have completely different names for the units..
Thanks. I've just never heard it refered to by that name.
Old Aug 13, 2009 | 07:45 PM
WymanD's Avatar
WymanD
Good info to know guys, mine does the same thing, also a 94.
Wyman
Old Aug 13, 2009 | 09:43 PM
pcolt94's Avatar
pcolt94
Correction:
Got to say you are technically right. I strayed a bit on my terminology.
The control head is called the control head.
But what I called the controller, is really the programmer. Which is the unit under the dash. I think it could be a better name but that is the official one.
Old Aug 14, 2009 | 09:57 PM
seijack's Avatar
seijack
This was the cure:
There is some good information on this thread. I will have to try this also..
To Heat and AC Controls...
Old Aug 16, 2009 | 02:37 PM
Pwnage1337's Avatar
Pwnage1337
WRONG.
I called NAPA, Advance Auto Parts, and AutoZone and NONE of them had access to the part.
Called a dealer, had it for $2.45.
You would think something so simple would be readily available..kinda like candy bars.
Old Aug 17, 2009 | 10:53 AM
josephf31's Avatar
josephf31
Default Right
Originally Posted by Pwnage1337
WRONG.
They DO have it, but it won't be in their computer, because it's a "generic" part you can find on the "Help" parts rotating parts rack! Just like lots of other part they "don't have"
Old Aug 24, 2009 | 11:27 PM
seijack's Avatar
seijack
This was the cure:
This works GREAT....I did it this weekend....Everything back is back to normal operation!!!!! Great Job rementis and pcolt94!!!
