Brake Upgrade Question.
Old Aug 6, 2009 | 03:21 PM
CAJUN C4's Avatar
CAJUN C4
Default Brake Upgrade Question.
Is it Worth it?
I'm considering Slotted Brake Rotors for my 95' It's only a Daily Street Driver.And Secondly,If it is worth it,What is the Best Brand to Buy for the Money.?
Old Aug 6, 2009 | 03:28 PM
pcolt94's Avatar
pcolt94
What a bold question to ask these days.
The slotted rotors are mainly for looks (cooling not an issue) on a street car and will not affect your braking. So if you like the look, get the slots. If you have sawblade wheels it doesn’t mater…..does it. But if you have the custom wheels, go for the look.
Old Aug 6, 2009 | 03:53 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
If you drive speed limits or your Vette is a garage queen, don't bother
Old Aug 6, 2009 | 10:16 PM
Elementaltoad's Avatar
Elementaltoad
The best investment I've made in my brakes so far, has simply been maintenance. I installed a set of Hawks HPS pads, new rotors all the way around (not fancy, but stock rotors provided by mid america) and then flushed the system refilling it with dot 4 brake fluid.
It stops very well and doesn't seem to have much, if any fade for my purposes. I do have the J55 option though, if you do as well, that is all you really need.
Old Aug 7, 2009 | 02:31 AM
bnio's Avatar
bnio
Don't waste the money on slotted rotors unless you really drive that car hard. Most owners don't so its not worth it. You braking limitations are going to be that theres no air ducting cooling the brakes and second the brake fluid. You could argue which comes first. Simply if you want to spend the money thats great have a blast, but it you aren't using the brakes to thier max potential slotted rotors won't do anything for you.
Old Aug 7, 2009 | 05:12 PM
CAJUN C4's Avatar
CAJUN C4
That's why I asked the question.Thanx Guys...you've answered my question.Stock is fine for me.
Old Aug 7, 2009 | 06:05 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
But dam! Do they look good....
Old Aug 8, 2009 | 09:33 AM
VETTEHIGH's Avatar
VETTEHIGH
YES!!!!!!!!!
Baer for me
Old Aug 8, 2009 | 11:40 AM
Heckler45's Avatar
Heckler45
I replaced my stocks with the Baer Eradispeeds and love 'em.
Old Aug 10, 2009 | 12:38 PM
'Shifter's Avatar
'Shifter
NCM Member '09
Originally Posted by VETTEHIGH
YES!!!!!!!!!
Baer for me
Not being able to invite Robin Leach ofver for supper, I just did the C5 conversion, and used Raybestos drilled/slotted, but had them zinc-plated so the center hat wouldn't corrode, and
look like buttock.
To Brake Upgrade Question.
