ZZ-9 Cam.....?
Old Feb 16, 2002 | 09:11 PM
StealDads67's Avatar
StealDads67
Default ZZ-9 Cam.....?
Hey guys, For the L98, I have been told the ZZ-9 Cam seems to offer the most performance and can still use it as a daily driver. I have also been old it can take up to .8 off your 1/4 ET. Sounds good too me :D . Does anyone have experiance with this cam, or others that you feel are really nice upgrade? Any Info would be helpful. Oh and is it a Roller Cam and what should i expect to pay for it? Thanks Again :cheers:
P.S. I was thinking when I get the Vette that I will throw in the Crane Gold Rollers and the ZZ-9 cam (I know there will be other things like valve springs if i need them and what not, im just trying to get an idea). From this what would you expect a 89 Vette 6spd be running in the 1/4??
Old Feb 16, 2002 | 11:07 PM
StealDads67
Default Re: ZZ-9 Cam.....? (StealDads67)
anyone? :confused:
Old Feb 16, 2002 | 11:11 PM
vader86's Avatar
vader86
its a good cam, i like Accel 219 better for a daily driver
go to http://www.tpis.com and look up the specs on the zz9.
Old Feb 16, 2002 | 11:33 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: ZZ-9 Cam.....? (vader86)
I have the ZZ9 and a miniram.. the times in the signature was before I started tuning the ECM
Old Feb 16, 2002 | 11:52 PM
StealDads67
Default Re: ZZ-9 Cam.....? (-=Jeff=-)
Is it me or is $375 a whole lot of money for a Camshaft.... even if it is Roller :eek:
Old Feb 16, 2002 | 11:57 PM
SlowJoe's Avatar
SlowJoe
HP=$$$$$$$$$$$$$$
Old Feb 17, 2002 | 12:16 AM
richN's Avatar
richN
I have the zz9 in my daily driven lt4 and the best advice I can give you is to keep looking for another cam.I am not so happy with the results of this cam or TPIS. they act as if they are the only people that can make these cars run. and so they get every one into the mindset that they are the greatest and then they charge the pants off you for there sub-par parts.If i was to do it all over again I wouldnt use this cam I would give a good hard look at competition cams or lingenfelter.best of luck
Old Feb 17, 2002 | 12:25 AM
StealDads67
Default Re: ZZ-9 Cam.....? (richN)
Does anyone else agree with "richN", they are damn expensive... I was looking at Crane, they seem to have some nice products. Crane had a Roller Cam and Lifter for the L98 for $259. And Im goin to use the Crane Gold Roller Rockers, so I always find it helpful to try and use the same brand. Thanks Again
Old Feb 17, 2002 | 03:06 AM
AS84's Avatar
AS84
I hope your not planning to throw a cam in an otherwise stock L98. I don't have any experience with tpis, but I do have the LPE 219. I have nothing bad to say about. It was a little pricey but in my opinion when you use it with the parts it was designed for its well worth it.
Old Feb 17, 2002 | 03:14 AM
vader86's Avatar
vader86
Default Re: ZZ-9 Cam.....? (AS84)
i agree with AS84, you need to decide what direction youre going-MR, SR, ported TPI, before you go and pick a cam.
Old Feb 17, 2002 | 03:16 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you go with a cam do full rollers (ProMagnums are very nice) and 7/16" studs. Also toss the oil sheders from atop the springs and install Ti retainers with 10deg locks.
At that point it would benefit you to pull the #113 heads (if you get a '88 or newer L98) and have them pocket ported, etc (check out the mail I sent you).
Check the e-mail data for expected 1/4 mi and HP gains. Although it's for a '90 Vette 6-speed, it should be close for an '89. Plus you won't need a chip to benefit, at least not right away.
Old Feb 17, 2002 | 09:33 AM
Oh My's Avatar
Oh My
Default Re: ZZ-9 Cam.....? (65Z01)
The zz9 cam is crap, pure and simple. It is a ripe off of the zz4 camshaft by GM. Just compare the specs. ZZ4 is 208/221 at .474 and .510 on a 1.5. The zz9 is 212/226 at .483 and .520 on 1.5. Yes its a bigger cam, but my god not big enough of a cam for 400 some dollars. Look at the cranes, good quality camshafts. I really do believe companies such as comp cams, Lunati, crower, crane, wolverine, etc. are more about getting people the right camshaft, then trying to get them to spend more money. Give them a call sometime, they'll offer some good advice.
Old Feb 17, 2002 | 06:39 PM
Red Rocket's Avatar
Red Rocket
Corvette Fever did an article on modifying a 90 L98 six speed and they did drop .7 in the 1/4 mile with this cam. Had the ZZ9 in my 350 LT-1 and was real pleased. 11.9 at 117MPH with a best of 119.5MPH in the 1/4 mile. The best NA time I've seen for a six speed Corvette LT-1 was with this cam.
[Modified by Red Rocket, 4:40 PM 2/17/2002]
Old Feb 17, 2002 | 06:50 PM
art91's Avatar
art91
Default Re: ZZ-9 Cam.....? (Red Rocket)
The ZZ9 cam was designed for use with a Miniram intake, not a TPI. A cam swap in a TPI without other changes, heads/intake/exhaust, isn't going to give you much gain anyway. Only changing part of the flow can even result in worse performance. About the biggest cam you can use in a stock, or large runnered TPI, is an LPE 74211. If you go to a Superram, then the LPE 74219 would be a good choice.
Good luck with your car. :cheers:
Old Feb 17, 2002 | 07:26 PM
dtorc4's Avatar
dtorc4
Default Re: ZZ-9 Cam.....? (art91)
If you don't want to pay $375, call Comp/Crane/etc. and have them custom grind you a cam of similar/same specs for half the price. :cheers:
Old Feb 17, 2002 | 07:39 PM
M2001's Avatar
M2001
I have a ZZ-9 cam for sale, it will cost you much less than $375. My price is $250 shipped to your door. I have it listed in the C4 Parts Wanted/For Sale section. I bought it as new from another forum member and I've never installed it. I'm going to selling my car so I have no need for it. Let me know if you're interested, my email addy is doublelife@microdsi.net. Thanks!
Old Feb 17, 2002 | 07:47 PM
Goody's Avatar
Goody
Default Re: ZZ-9 Cam.....? (M2001)
Listen to the years of experience on this board. Do not swap that cam into a stock engine. It isn't made for it. Upgrade the exhaust, intake system first or at the same time....otherwise you will be disappointed. The rockers are okay to do so long as you check for coil bind if going larger than 1.5. Good luck and enjoy. :seeya
To ZZ-9 Cam.....?
Old Feb 17, 2002 | 08:05 PM
StealDads67
Default Re: ZZ-9 Cam.....? (Goody)
I dont kno where you guys got the impression that Im just gonna through it in a stock engine im def not. But i didnt take the time to go to the original post so it may have given off that impression. My pops would port and polish the heads and Runners for me (so thats pretty cool), K&N open lid intake, headers, and a cat back, then from there i wanted to do the Cam, lifters, Valve Springs and rockers. So Its def not going to be stock. I want to know this stuff now so when I get the Vette i can just jump right into it knowing what works best, Thanks guys :cheers: :cool: :cheers:
Old Feb 17, 2002 | 08:23 PM
bill mcdonald's Avatar
bill mcdonald
I have the ZZ9 cam in my daily driver. I find it is just fine even with 1.6 Roller rockers.
I have not ran it at a track yet so I cant see how it compares to others cars.
But for sure, if you go ZZ9 cam, you need a Super ram or a Mini Ram.
There is no point to having a TPI on a motor with that cam, you will be choking it!
Old Feb 17, 2002 | 08:30 PM
vader86's Avatar
vader86
Default Re: ZZ-9 Cam.....? (bill mcdonald)
No, even with ported plenum and runners it wont be enough for a 219 or ZZ9 cam, you should go 74211 or a Comp Cam.
