Engine blew up
In my own experience, engine disasters almost always involved top end failures. The late Smokey Yunick allegedly said that the small block chevy lower end could be made to turn 10,000 rpm, it was all that monkey motion on top that limited it's performance.
What kind of timing #s were you running at those rpms? What ecm/tune etc do you have? Are those SRP Pistons?
I still have to disassemble the heads to be sure.
it before (by lower end I mean block, crank, rods and pistons).
Here are timing maps. It's custom tune by PCMForLess. I've been driving
the car with this tune for approx. 3 years now.
I'll probably have it micropolished also.
I used to have another car with a 351 cleveland engine , 8,500 rpm no probs with anti pum up hydraulic lifters .. the only problem was dropping valves as you have had ... that was solved by replacing the valve stem collets they wear realy badly at over 6000 rpm so i used to replace them every 2 months. So look at the valve stem and collets for wear
I had that engine reving to 8500 rpm a lot was a nascar spec engine and the valve collets are a weak point ....
By the way my vette doesnt have to rev to 6500 rpm with the supercharger as it has so much torque at lower rpm
with a hydraulic ? THey are so much more dependable up top, no parts in the lifter to go bad, pump up, etc. Dont know why people are so scared of them.
For repairing this engine, I allready have LS-x lifters.
They are supposed to be better and should be good up to 6500
what will be my redline.
Pistons are stock. Complete lower end is stock, I have never opened
Will do. I'll have to have it rebalanced for new rods and pistons also.
I know you did not ask but if this is your total WOT spark advance it is too conservitive and you could pick up good power with more advance. Typical SBC like 30 (fastburn heads) to 36 (Standard combustion chanbers) degrees of advance at WOT.
I gained too little with SR install. Maybe this was where the
power was hidden.
But it won't matter too much now, I'll go with a different cam
with this rebuild.
It'll definately need a sleeve. I'll have the block checked, but I can
already tell by the look that 0.020" overbore ( I allready have that size pistons ) won't be enough.
I did it for two reasons:
1. to check if weak spring was a problem
2. to check if I could reuse springs with new cam.
However, I got some strange readings.
1.900" - 112 lbs
1.800" - 157
1.700" - 199
1.600" - 242
1.500" - 288
1.400" - 334
1.300" - 390
1.200" - 456
It's a little bit hard to be really precise with valve spring tester that I
used (see link below), but all springs were very similar.
The weakest one was 364@1.300" and stronest 392@1.300".
Link for the spring tester:
http://www.streetperformance.com/par...760-66834.html
The scale is by 10 lbs, so my numbers could be 1-2 lbs off, but even
if they are 10l bs off, it still looks like those are a lot of
springs for small #219 cam.
I'm about to install XR-288HR cam that has alot more duration than
LPE #219 cam, similar lift and it needs less springs than what I've got.
This are springs that are recomended for XR-288 cam:
Comp Cams #249-986-16
Dual Valve Springs
Outer inside diameter: 1.070"
Inner inside diameter: .697"
Seat load: 132lbs @1.750''
Open load: 293lbs @1.250''
Coil bind: 1.150''
Rate: 322lbs/in
OR
Comp Cams #249-987-16
Dual Valve Springs
Seat load: 121lbs @1.800''
Open load: 343lbs @1.200''
Coil bind: 1.150''
Rate: 370lbs/in
What is your opinion on this? How is it possible that from 1.900" to 1.800" is 45 lbs and from 1.300" to 1.200" is 65+ difference? Is that valve tester any good at all, can it be that much off? Can it be that springs that came with from LPE are ~450lbs/inch rate???
