86 coupe lowering front
Old Aug 14, 2009 | 10:31 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default 86 coupe lowering front
Can I sand the front wedges down to a specific height instead of buying the wedges? If so, what is the height I should belt sand them down to? I also read about cutting my brackets because they keep the spring tight. I do have access to a welder and cutting tools. I would like the front to be as low as possible.
Old Aug 14, 2009 | 10:52 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
86 doesn't have a solid rubber, so you will need something to glue on. The bracket will need to be cut, shortened and welded.
