Steering Wheel Centered?
Old Aug 15, 2009 | 11:31 PM
C4-90-41001's Avatar
C4-90-41001
Default Steering Wheel Centered?
I had a reputable local shop fix the sloppy tilt steering wheel problem on my '90. (The infamous pivot pin problem). That issue is now a thing of the past which is great.
Problem is, it seems as if the steering wheel is now rotated a few degrees clockwise when going straight ahead.
But according to the FSM, the steering wheel will "only fit in one position" which makes me wonder if it was never exactly centered and I just didn't notice until now.
Before I take the car back to the shop and look like an idiot to the wrenches there, I wanted to ask you guys: Is it possible for the steering wheel to be a spline or two off or does it only go on one way?
Thanks!
Old Aug 15, 2009 | 11:44 PM
josephf31's Avatar
josephf31
Default From
Thanks!
what I remember it goes on only one way.
Just out of curiousity how did they fix the pivot pin problem?
Old Aug 15, 2009 | 11:53 PM
C4-90-41001
The pivot pin hole on the left was wallowed out quite a bit so he fashioned a shim and stabilized it and then used JB Weld to give it more strength and prevent the pivot pin from backing out.
It's a new repair so we'll see if it holds up but I watched him do the repair and it looked like the best he could do in the absence of having a new aluminum housing.
Thanks for answering my question. Since I did the post, I've looked at some photos of the end of the steering column and I see that the splines are not uniformly spaced on the shaft so it would seem your memory is correct.
mtwoolford's Avatar
mtwoolford
I replaced the steering column on my 96. When I put the steering wheel back on I probably missed by one spline, and believe me, there are plenty of splines. The result, the steering wheel was off center ever so slightly, but just enough to be annoying. A trip to the alignment shop fixed everything.
Good luck, save the wave, and enjoy your corvette.
Old Aug 16, 2009 | 12:00 AM
C4-90-41001
Did you leave the wheel as it was after the replacement and have the alignment shop correct the tracking?
I'm asking because as I was telling Josephf31, in some photos I found, the splines do not seem to be uniformly spaced which would seem to indicate that the wheel can only go on one way.
Old Aug 16, 2009 | 01:23 AM
M. Schumacher's Avatar
M. Schumacher
In order for the turn signals to cancel properly the wheel has to be centered first before aligning.
Old Aug 16, 2009 | 01:26 AM
383vett's Avatar
383vett
Point the steering wheel straight in your garage. The front wheels will be aiming either right or left depending on what direction your steering wheel was off. Figure out how the threads work on your tie rods and turn each side the same amount to straighten the front wheels. If you are careful and make the same change on both sides, you will not change the alignment but the car will go straight relative to the steering wheel. It's really not difficult and will save you some $$$.
Old Aug 16, 2009 | 08:38 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old Aug 16, 2009 | 12:56 PM
C4-90-41001
Thanks to all for the help.
To Steering Wheel Centered?
