Driving down road engine cuts back, then OK
Old Aug 19, 2009 | 07:24 AM
Mark_Sheehy's Avatar
Mark_Sheehy
Default Driving down road engine cuts back, then OK
I have a 90k mile, 1989 convertible. 3 times it has acted weird just driving down the road. I will be going along fine and then the engine cuts down by itself, there is no response at all if you hit the gas pedal, then it comes back on its own and is working fine.
- It does not run rough at all, it is there, gone and then comes back again, running smooth before and after the issue.
- The engine has not died during this issue.
- I believe all 3 times the car was under light acceleration, as in moving away from a light once and a stop sign twice.
- Twice it has lasted about a second, the other time maybe 4 seconds.
The manual says to start with the fuel filter, so that is what I did yesterday, and it did it again on the way home, so that didn't solve it. It has not set any codes so far.
This is what I have done so far:
- Fuel filter brand new (AC replacement) 8/18
Old one appeared fine, could easily blow through it
- Ohm test injectors, all from 16.5 to 17.0 ohms
- Fuel pressure test
Running 40 psi
Rev it up 45 psi
Shut off 40 psi
45 minutes later 29 psi
- Tapped MAF while engine running with a screwdriver, no issues
The mechanic said to clean the MAF, does this make sense? Does anyone have any ideas on what is wrong?
Thanks for any help you can give me.
Old Aug 19, 2009 | 08:45 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
How much fuel was in the tank ??
Did you ohm test injectors when "hot" ??
Old Aug 19, 2009 | 10:10 AM
engle1147's Avatar
engle1147
There are some horror stories on this fourm about the problematic OEM multechs that were installed '89s and the surrounding years. A great number of people have swapped their stock Multechs (non ethenol compliant)in for a set of Bosh III (ethenol compliant)....myself included.
Things to check (other than the fuel injectors):
Fuel pressure regulator diaphram leaking.
The wire to the O2 sensor...make sure it isn't grounding to the exaust or heat shields while driving.
Old Aug 19, 2009 | 10:16 AM
my83432's Avatar
my83432
This doesn't sound like a fuel related problem. Hard starts smell of gas and stumbling are more what see with a fuel problem. This sound more like the ignition system.
Old Aug 19, 2009 | 10:28 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default ECM Chip ?
Possibly ECM chip connection loose or chip going bad. These chip sets are notorious for intermittent failure. May have thrown a Code 33 - check it out.
Old Aug 20, 2009 | 07:24 AM
Mark_Sheehy
Thanks for chiming in, answers below.
The tank was full the first time, 1/2 full the second time, 1/4 full the third time.
The ohm test was cold. The injectors are 3 years old, but only about 1200 miles on them.
It does not run rough or miss when this happens, it is like someone shut it off completely, then it comes back. But the engine never dies.
Wouldn't I see the pressure drop off faster if the regulator diapragm was leaking? It is still 29 psi after 45 minutes of sitting.
No smell of gas when this happens. Car starts fine.
Old Aug 20, 2009 | 07:39 AM
ddahlgren's Avatar
ddahlgren
Ignition module or coil would be my first guess for a quick cut off then on. Overheats cuts out cools of and runs again. If not that a bad connector somewhere and sure hope not that could be a long search..
Old Aug 21, 2009 | 07:15 AM
Mark_Sheehy
Thanks ddahlgren.
I am leaning electrical as well. The first time it did this I had just left my garage and had just pulled out onto the main road, so the car was not even warm yet. The second time, which was the worst, about 3-4 seconds, it was completely warmed up. The third time was just about completely warmed up.
I also fear a loose connector somewhere, could be anything anywhere then.
Old Aug 21, 2009 | 08:39 AM
ddahlgren's Avatar
ddahlgren
Has anyone done anything before this happened in at least recent past under 500 miles ago? if so start there or at least in that area.. Fixed radio heater anything under the dash or engine compartment? I know the engine dying is very distracting but if all possible see if you can notice anything else not working.. May be on a common circuit or ground wire. See if something magically goes on light anything that would also be a ground wire somewhere. Open hood start car and start wiggling wires and see if you can make it fail.. On an L98 there is a pigtail on the distributor that you can not see easily with the cap on. Mine was rubbing the firewall and put some of that black plastic covering on it like the rest of the car has. If that shorts the car will stop.. It wouldn't hurt to check the connectors for the distributor coil ign module etc. Hit them with some contact cleaner and make sure the pins have plenty of tension. You want them stiff enough so it is a tiny struggle to put them together. That has fixed dozens of things on my car.. If all else fails start cleaning ground wires they are buryed everywhere sorry to say..
Old Aug 21, 2009 | 11:57 AM
vette079's Avatar
vette079
Try battery cable...
Old Aug 21, 2009 | 01:45 PM
rick lambert's Avatar
rick lambert
Pull the Ignition Control Module, take it into AutoZone, they'll test it free, just make sure they cycle it at least 10 times.
Old Aug 21, 2009 | 03:53 PM
Mark_Sheehy
This started out of the blue, didn't do anything to the car since last year.
Sounds like the consensus is electrical, thanks for the input.
Old Aug 21, 2009 | 09:37 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Had similar sounding problem, it was MAF relay
Old Aug 21, 2009 | 10:43 PM
tblt44's Avatar
tblt44
Coil ???????????
Old Aug 24, 2009 | 07:18 AM
Mark_Sheehy
Thanks for the input. Does the MAF relay control when the MAF wire gets heated up to clean it? That would make sense with what the mechanic said to just clean it with spray.
Old Aug 24, 2009 | 07:56 AM
floridamale's Avatar
floridamale
There are 2 MAF relays one controls normal MAF signals the other controls burn off. I believe burn off happens after you turn off car, the wire in MAF is super heated to remove any residue.
Old Aug 24, 2009 | 08:25 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
The burn off relay is generally not the prpblem, it is the signal relay
Be sure though to replace both relays at same time...per Gorden K, replacing one creates overload and burns one up
Have you checked for codes? This condition should throw codes
be careful spraying anything into MAF and don't spray anythimh with solocone in it
To Driving down road engine cuts back, then OK
Old Aug 25, 2009 | 07:25 AM
Mark_Sheehy
Thanks for the input. It hasn't set any codes so far. I thought I would raplace both MAF relays while I was at it. I didn't want to spray anthing on the MAF because I believe I read on on this board quite a while ago that it wasn't a good thing.
Old Sep 12, 2009 | 09:56 PM
TAW1957's Avatar
TAW1957
Mark, I am having the same issue with my 93. Runs great for about 20 minutes, or until it warms up, then stumbles, at first it never stalled but has progressively gotten worse. I'm not throwing an codes either, checked the ICM & I've already been through the fuel and vacuum systems, replaced the EGR, etc.but not the coil. I bought a new factory coil today and will install tomorrow and let you know what happens. But my symptoms sound exactly like yours.
Old Sep 13, 2009 | 07:44 PM
whitey16's Avatar
whitey16
Default Responce and Question?
I had the exact same symptoms with my 96. Would be running fine and all of a sudden I would lose all power. Once or twice it stalled, but would start right back up. Turned out to be the alternator needed a rebuild! It hasn't acted like that since.
Now I have another problem. Very random, no power whatsoever. Turn the key, nothing, no lights, no cranking, nothing. Got out, opened hood. Looked for something obvious, loose battery cable, corrosion. Shut hood, and started right up and ran fine. I'm thinking maybe bad ground. Any other ideas, anyone?
Oh, and thanks ahead, new here, loads of good info and knowledge!
