Radiator Replacement
Old Feb 18, 2002 | 01:47 PM
Lastc4's Avatar
Lastc4
Default Radiator Replacement
Any input on radiator replacement? Stock vs. aftermarket all aluminum, is it worth the extra money?
Old Feb 18, 2002 | 02:15 PM
RatRacer's Avatar
RatRacer
Default Re: Radiator Replacement (Lastc4)
Unless you have a very modified engine it's hard to justify the cost of an aftermarket rad. A stock replacement rad is only $220.
Old Feb 18, 2002 | 02:33 PM
Lastc4's Avatar
Lastc4
Default Re: Radiator Replacement (Cam Potter)
$220.00? Where? I'm hearing around $370.00!
Old Feb 18, 2002 | 02:35 PM
ralexand's Avatar
ralexand
I just replaced the raditor in my 90. The Delco stock replacement was $197 at A-Line Parts. Took about 2 hours to install. Piece of cake. The hardest thing was draining the old coolant...
Old Feb 18, 2002 | 03:14 PM
VetteNoob's Avatar
VetteNoob
Default Re: Radiator Replacement (ralexand)
I just replaced mine for $130 (shipped) from http://www.radiator.com. It is the SAME quality as the stock ones. Aluminum tube w/ nylon tank.
[Modified by VetteNoob, 1:15 PM 2/18/2002]
Old Feb 18, 2002 | 04:23 PM
Lastc4's Avatar
Lastc4
Default Re: Radiator Replacement (VetteNoob)
Thanks for the info, $157 + shipping from radiator.com, $196 from a local Auto Zone for a GM replacement.
:chevy
Old Feb 18, 2002 | 08:17 PM
corvette1990's Avatar
corvette1990
I had a stock replacement put in mine. I asked about the expensive aftermarket ones, but was told unless I was makin 500 HP, the stock one would do fine. What a diff in cooler temps with a new rad. The old was clogged, and the side plastic had expanded from an overheat during the summer.
To Radiator Replacement
