Inner Door Panel Broken Tabs
Old Aug 24, 2009 | 11:36 AM
bubbleheaddiver89's Avatar
bubbleheaddiver89
Default Inner Door Panel Broken Tabs
Hi, I'm Patrick and have a 1992 Corvette. I've not been able to find any info on a problem I have with some partially broken tabs on my inner door edge. It appears to be broken in two places:
Has anyone else had this problem? My thoughts are to add a piece of thin angled aluminum and attach it to the door. The door panel on the side is also cracked along the top and the numerous posts on how to fix that problem were very helpful. I appreciate any help you can offer!
Thanks,
Patrick
Old Aug 24, 2009 | 04:04 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
My guess would be is that you could use a piece of sheet metal to form a new lip and pop rivet it to the frame or use glass mat and resin to build a new lip on it.
Old Aug 24, 2009 | 05:04 PM
M. Schumacher's Avatar
M. Schumacher
http://forums.corvetteforum.com/c4-t...indow-fix.html
Old Aug 24, 2009 | 05:14 PM
bubbleheaddiver89
Thanks for the suggestions and link. It looks like something similar will work for me.
Old Aug 24, 2009 | 05:16 PM
M. Schumacher
As you can see it's a common problem. Mine has it too. I'll tackle it when she is hibernating for the winter.
To Inner Door Panel Broken Tabs
