Suggested header bolts LT1
Old Aug 24, 2009 | 09:57 PM
C4fan's Avatar
C4fan
St. Jude '10
Default Suggested header bolts LT1
I'll be installing my SW headers soon. Anyone have a suggestion (part #) for header bolts? Hex head or 12 point? Brand?
Old Aug 24, 2009 | 10:35 PM
Jake Dragon's Avatar
Jake Dragon
I picked up some bolts at Autozone. They use a Allen wrench and have safety wires to keep them from backing out once you have them installed. The set comes with a socket Allen wrench to install them.
Old Aug 24, 2009 | 11:16 PM
eguyett1985's Avatar
eguyett1985
I use the ARP SS hex bolts on my headers, the part number is 400-1109 with a 1" length. I like them because the heads are 5/16" instead of 3/8" so you can get in and tighten them easier and with a hex head you can use a socket, open or closed end wrench.
Old Aug 25, 2009 | 12:56 AM
pr0zac's Avatar
pr0zac
i don't have sw's but with my shorties i was able to use an allen head bolt that i got a 1/4 longer and put a lock washer on and they never backed out.. this idea didn't work with my EM lt's cause the primaries were too big.
Old Aug 25, 2009 | 04:00 AM
Weav's Vet's Avatar
Weav's Vet
I used stainless steel studs instead of bolts when I did my SW's
ARP-400-1412 from Summit
http://www.summitracing.com/parts/ARP-400-1412/
They worked ok but there are a couple that are still a PITA to tighten. Still tight though with no leaks.
Old Aug 25, 2009 | 07:27 AM
C4fan's Avatar
C4fan
St. Jude '10
Just curious, why did you change to studs?
Old Aug 25, 2009 | 07:31 AM
Weav's Vet's Avatar
Weav's Vet
Just seem tomake more sense to me. A nut seems easier to start than a bolt in those tight spaces.
JFYI I had to wobble out the end guide pin holes on my SW headers. After they went on the guide pins some of the bolt holes didn't line up very well. I don't know if it was because of the studs or not. I have never read of anyone else having this isssue.
Old Aug 25, 2009 | 07:43 AM
Strick's Avatar
Strick
I bought S/S allen socket head bolts that were 1" in length. These made it easier to use a torque wrench with and look cool. The only place I didn't use these at was where the A/C alt brace bolted to the header with a standoff type bolt.
Old Aug 25, 2009 | 08:02 AM
Muffin's Avatar
Muffin
What he said.However I think I'll try the stud thinges on my next build.
Old Aug 25, 2009 | 08:44 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I used: ARP 400-1209 - ARP Stainless Steel Header Bolts
Old Aug 25, 2009 | 09:12 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Any of you guys using NordLocks?
http://www.nordlock.com/
Old Aug 17, 2023 | 01:40 PM
josephc4's Avatar
josephc4
I know this thread is 14 years old. But I don't see how ARP 400-1209 bolts can be used in an LT1 C4. Pictured here is an OEM LT1 header bolt (I just removed from my '95 C4) next to ARP bolts 400-1209 bolts. The ARP bolts aren't even half the length of the OEM bolt. What am I missing?
ARP 400-1209 Header Bolts vs OEM LT1 C4 corvette header bolt.
Old Nov 5, 2024 | 01:58 PM
Deanhinton's Avatar
Deanhinton
6th Gear
This is an old thread, but the stock exhaust headers had a much deeper flange than aftermarket ones like ARH, etc. The bolts that come with my new headers were 1” long and the flange measured 0.39” thick. Hope that helps.
To Suggested header bolts LT1
