Code 44 Lean Exhaust
Old Aug 25, 2009 | 02:25 PM
Pwnage1337's Avatar
Pwnage1337
Default Code 44 Lean Exhaust
Yesterday i was driving along, everything was fine. Check engine light comes on for about 15 seconds then goes away. Get home, pull codes and its a code 44.
I looked it up in the FSM and it says to run the car until warm so i drove it around for 10 minutes. Then it told me to ground the diagnostic terminal, so i did and it was flashing the check engine light once per minute which indicated that the car was in closed loop mode.
The FSM says that the code is intermittent.
Now my question to you guys is..lately i've been experiencing **** poor mileage. my instant readout at 60 mph is 17 mpg. it used to be up in the high 20's and sometimes even seeing 30.
Is this a bad oxygen sensor?
Old Aug 25, 2009 | 03:00 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Bad O2 would be my guess. Do you have access to a scanner? You could check the actual O2 reading.
Old Aug 25, 2009 | 03:31 PM
WW7's Avatar
WW7
About 3 weeks ago I discovered my 89 was running lean,the Block learn was at 146.. Replaced the O2 sensor and all is well, but the only way to know for sure is to hook up to a scanner..If the block learn is higher then 128 the car is running lean, if its lower then 128 its running rich,the ecm can correct for this to a certain degree but the numbers should be somewhere around 128..The integrater should also be around 128, the integrater is your short term fuel/air correction, Block learn is long term.Also don't rule out a vacuam leak for causing a lean condition ..WW
Old Aug 25, 2009 | 03:37 PM
jeffp1167's Avatar
jeffp1167
low fuel pressure will trip 44
Old Aug 25, 2009 | 04:11 PM
JAKE's Avatar
JAKE
When my L98 did that, it was a failed 02. A scan pin-pointed it.
Jake
West Point ROCKS! Nation's TOP COLLEGE per FORBES Magazine!
Old Aug 25, 2009 | 07:46 PM
Pwnage1337's Avatar
Pwnage1337
What do I need to scan my 85?
Old Aug 26, 2009 | 08:17 AM
WW7's Avatar
WW7
Any scanner that is (OBD 1 ) will work..WW
Old Aug 26, 2009 | 09:54 AM
-=Tom=-'s Avatar
-=Tom=-
Bad o2 sensor. I just changed mine a few weeks back on the driver's side.
Old Aug 26, 2009 | 10:10 AM
Pwnage1337's Avatar
Pwnage1337
Replaced 02 sensor, mpg didn't change..fouled plugs or vacuum leak? I checked my plugs a while ago and some had some oil on them especially cylinder 7.
Old Aug 26, 2009 | 11:30 AM
Aardwolf's Avatar
Aardwolf
When you were here it looked like you left your cruise vacuum line open and had a vacuum leak.
Old Aug 26, 2009 | 02:15 PM
Pwnage1337's Avatar
Pwnage1337
fixed it the day i left your house lol.
Cruise works now, still no climate control..I'm going to start a new thread with some wierd stuff going on with the damn fuse box.
Old Aug 27, 2009 | 09:18 AM
-=Tom=-'s Avatar
-=Tom=-
Which one did you change? How do you know you changed the right one? It also takes some driving to re-learn. I know when I changed mine it took at least an hour or so of driving for the MPG to get back to it's usual norm.
Old Aug 27, 2009 | 12:59 PM
Pwnage1337's Avatar
Pwnage1337
Mine only has one, its on the drivers side in the Y-pipe.
Should I disconnect/reconnect the battery?
I put new plugs in it too, some of them were looking pretty beat up. Cylinder 7 has oil on the threads of the spark plug..what does that mean?
Old Aug 27, 2009 | 01:10 PM
Aardwolf's Avatar
Aardwolf
Probably just from your leaking valve cover gaskets. There's no oil on the ground strap etc right? I remember you posted about having an exhaust manifold gasket leak, is it on the side with the O2? That could throw some codes.
Old Aug 27, 2009 | 03:29 PM
Pwnage1337's Avatar
Pwnage1337
Ground strap is clean so i guess its the VC's leaking. I can't really tell if the exhaust manifold is leaking, but would that really effect my mileage that much?
Before i put the new runners and stuff on, the mileage was good..it makes me think that its a vacuum issue, or maybe a fuel injector or something.
Old Aug 27, 2009 | 03:46 PM
JAKE's Avatar
JAKE
Even the smallest exhaust leak can cause a lean condition.
I once had a tiny pin-hole leak develop in the #5 TPIS header tube, too small to even see without looking very carefully for it. That caused a lean condition indication.
Jake
Old Aug 27, 2009 | 03:50 PM
Pwnage1337's Avatar
Pwnage1337
Jake
****. I guess I will have to check for exhaust manifold leaks..whats the best way to find one?
To Code 44 Lean Exhaust
Old Aug 27, 2009 | 03:58 PM
Aardwolf's Avatar
Aardwolf
How'd you find it the first time? Check for carbon tracing, might need a mirror to check the bottoms.
Old Aug 27, 2009 | 03:59 PM
Pwnage1337's Avatar
Pwnage1337
My dad pointed it out to me, I have no idea how he saw it. It wouldn't be possible for it to reseal itself somehow would it? Could i just start the car and feel for leaks with my hand before it gets hot?
Old Jun 28, 2021 | 09:14 PM
Lemon Pro's Avatar
Lemon Pro
2nd Gear
Yes, on my 1985 Corvette and after many hours of doing everything everyone said may be the cause for the Lean Condition Code 44 were all wrong.
Here is how it works and why you got the Code 44.
First the EGR open when the EGR Temperature Sensor tells the computer the engine temperature is 175 at the EGR Valve.
The EGR Temperatures Sensor, sends a signal to the ECM,
The ECM sends a signal to the EGR Vacuum Regulator
The EGR Vacuum Solenoid open or closes the EGR Valve so the engine valves can be cooled and the air fuel mix is properly adjusted.
I replaced the EGR after testing when it dropped after a few minutes with a thump, still had 44.
The EGR Vacuum Solenoid worked electrically but the vacuum was leaking and I replaced that, still had 44.
The Code 44 stayed after the EGR and EGR Vacuum Solenoid were replaced as well as the Computer,
After full aggravation I replaced the EGR Temperature Heat Sensor, that was it, no more Code 44.
I recommend if you have a Code 44 get the new Temperature Heat Sensor it is only $76 and solves that problem.
