Thread locker on rocker studs ?
Old Aug 26, 2009 | 02:54 PM
92ZR1WANNABE's Avatar
92ZR1WANNABE
Default Thread locker on rocker studs ?
Just got my heads back and am ready to start putting the hardware on.
Is it suggested to use thread locker on the rocker arm studs? Perma or not?
Locktight Red?
Blue ?
Help
Old Aug 26, 2009 | 03:21 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Are you confusing thread sealant with thread locker ??
Old Aug 26, 2009 | 03:29 PM
92ZR1WANNABE
No
Thread sealant keeps the water where its supposed to be.
Thread locker keeps the bolt where its supposed to be.
Just not sure if rocker arm studs require the use of locker or not.
Old Aug 26, 2009 | 04:04 PM
Aardwolf's Avatar
Aardwolf
I use the same sealant I use on the head bolts.
Old Aug 26, 2009 | 04:11 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Screw in studs dont have a tendency to pull out or loosen like press in studs. I think you would be safe with the blue.
Old Aug 26, 2009 | 05:31 PM
Tulsa Vette Guy's Avatar
Tulsa Vette Guy
Default Blue
When I was rebuilding I would use BLUE,, Do not use RED, It takes heat to remove.
Old Aug 26, 2009 | 05:50 PM
engle1147's Avatar
engle1147
Use the blue....torque normally
Old Aug 26, 2009 | 06:39 PM
STL94LT1's Avatar
STL94LT1
If the heads have been ported you'll need thread sealant on the intake studs. The threads can go all the way through to the intake ports and can pull oil in if not sealed.
Old Aug 26, 2009 | 07:25 PM
aboatguy's Avatar
aboatguy
If ported use sealer. Unported I wouldn't sweat using threadlocker.
Old Aug 27, 2009 | 09:24 AM
AGENT 86's Avatar
AGENT 86
Originally Posted by 92ZR1WANNABE
No
I was thinking you read something somewhere and misread locker for sealant.
Sealant is the normal choice and is recommended by GM and most cylinder head manufacturers.
Old Aug 27, 2009 | 11:31 AM
92ZR1WANNABE
Thanks!
Old Aug 27, 2009 | 03:39 PM
JAKE's Avatar
JAKE
Yep, sealant is what to use. It helps prevent a vacuum leak and/or oil being sucked into the intake ports.
If torqued correctly, studs don't loosen or back out, so no thread llocker is needed.
Jake
West Point ROCKS! Nation's TOP COLLEGE per FORBES Magazine!
To Thread locker on rocker studs ?
