convertor lockup???
Old Sep 2, 2009 | 06:15 PM
ironvapor's Avatar
ironvapor
Default convertor lockup???
Anyone know the speed in mph that a torque convertor should lockup on a 700R4 in a 1989 with a stock ecm and chip when driving in overdrive???
Old Sep 2, 2009 | 06:54 PM
PAINTER MAN's Avatar
PAINTER MAN
Mine locks at 42 MPH.
Old Sep 2, 2009 | 07:24 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
42-45 MPH
Old Sep 2, 2009 | 07:38 PM
Weav's Vet's Avatar
Weav's Vet
Originally Posted by JrRifleCoach
42-45 MPH
yep
Old Sep 2, 2009 | 10:34 PM
ironvapor's Avatar
ironvapor
The reason I asked is I had a hypertech chip in the ECM and I was getting lockup at 42 mph. I took it out because once the cooling fan came on it wouldn't go off and put the stock chip back in and now I am getting lockup at 35 mph. I don't remember what it did prior to installing the hypertech chip but I guess it was 35 mph. Thanks for the input one and all.
Old Sep 2, 2009 | 11:33 PM
pletzvet's Avatar
pletzvet
At normal operating temperature, my stock '85 locks at 68 kph or 42 mph consistently. I jumpered a toggle switch into the power wire at the brake switch, which when the toggle switch is open - it replicates the brake switch being activated (no brake lights on, of course) unlocking the TC until I switch it back on with the toggle. Works nice on cruises and in areas where the speed limit is right around the lock up speed.
Old Sep 3, 2009 | 12:33 AM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
I sure hope that you are monitoring your trans fluid temp. When the tc is not locked up it is constantly generating more and more heat due to friction. If you hold that tc in an unlocked position for an hour of driving your going to drive the trans fluid up quite a bit. Just my .02
Old Sep 3, 2009 | 12:46 AM
pletzvet's Avatar
pletzvet
Yep...you're right! I am well informed of the increased trans fluid temps if used under prolonged circumstances. Wouldn't think of driving it down the highway for any length of time in unlock mode. Really - there is no purpose that I can see in running in in unlock mode for extended periods of time. Only intended to disengage the TC lock up for brief periods of time when the engine lugs down - like when cruising up a hill at about 70 kph.
Old Sep 3, 2009 | 01:19 AM
JrRifleCoach
My switch "locks" the TC and holds it until the brake is applied. I found that cruise speeds of less than 45mph can be accomplished with 3rd gear and the TC locked.
Haven't we all ready talked about this before????
Old Sep 3, 2009 | 01:32 AM
Calderone's Avatar
Calderone
what you feel or how you know when its locked or unlocked ?
Old Sep 3, 2009 | 06:53 AM
WW7's Avatar
WW7
Sammy, If you touch the brake pedel for a second while going down the road around 45 mph you will feel the converter unlock then lock right back up again, it feels like a gear shifting...WW
Old Sep 3, 2009 | 07:17 AM
Calderone's Avatar
Calderone
yes,i know that feeling but what if you buy a non lockup? i know they waste gas
they are locked all the time ? strange,i know the feeling but i dont know exactly
when it locks or unlocks ...for example if im cruising and there is an uphill,does it unlock?
if im going faster im unlocked ? lol ...its confusing !
Old Sep 3, 2009 | 08:01 AM
pletzvet's Avatar
pletzvet
Using your 3rd gear selector is another option, if that's your preference. I don't think this is the only topic on the forum that has been "talked about" before...did I miss a ruling about that?
Old Sep 3, 2009 | 09:08 AM
rodj's Avatar
rodj
what if you buy a non lockup? they are locked all the time
No .
A non lockup convertor is just like a convertor installed in millions of trans before pollution / economy became a concern .It just means that the trans is never running at engine revs; there is alway a percentage slippage.The lockup feature is for economy only.
As above , running unlocked no different to any non lock up trans ;TH400 /Glide / TH350 .The heat is from slippage ; not friction.
The PROBLEM with T700/4L60 is that it does not have full fluid flow to the cooler unless it is in lockup mode hense the stated concerns about overheating of trans when running unlocked.
Old Sep 3, 2009 | 04:13 PM
Mr. Peabody
Originally Posted by rodj
No .
Wow thank you for that.
I never realized that flow to the built in trans cooler within the radiator doesn not occur unless the tc is locked.
Can you explain this in a bit more detail. How is the fluid flow to the cooler controlled.
My situation is that my tc does not lock up until 48mph in 4th. In my daily commute I unfortunately spend much of the time at speeds lower than this and the trans temp just continues it's steady rise in temp. To the point where the water temp = 190 but the trans fluid temp is 40 degrees higher.... however once I hit 48 and the tc locks up the temp will hold (at what ever temp is was at that point) and not rise any further and infact over enough time it will fall to within 10-15 degrees (f) of the water temp.
PS I thought slippage and friction were essentially the same thing.
Old Sep 3, 2009 | 04:32 PM
bjankuski's Avatar
bjankuski
The older 700 did not have full flow to the oil cooler until they were in lock-up 1985 and earlier. If you have a 1986 or newer that issue was resolved and you will have full flow to the oil cooler when it is not in lock-up.
Old Sep 3, 2009 | 05:56 PM
rodj's Avatar
rodj
So on that basis all the stories/myths / rumours of burning up your (post '87) trans if running unlocked are unfounded ?
Bad for fuel economy; yes but not bad for trans.
To convertor lockup???
Old Sep 4, 2009 | 10:05 AM
bjankuski's Avatar
bjankuski
The answer to your question is yes you can run the transmission unlocked and no damage will result as long as the transmission can stay cool. Idealy you would like to keep the transmission oil temperature at or under 180 degrees for best life. In the real world that is hard to do, so 200 degrees is a common accepted transmission oil temperature. Once the transmission oil temperature exceeds 200 degrees the life of the transmission drops quickly.
An overdrive transmission puts more torque load on the convertor at any speed when it is running in overdrive (as compared to an older style 1:1 nonoverdrive transmission). This torque load creates slip and heat so the general rule of thumb for an overdrive transmission is to use lock-up when in overdrive to keep the oil temperature lower. If the oil temperature when in overdrive nonlock-up can be kept under 200 degrees the transmission will not have any issues with the nonlock-up torque convertor.
Old Sep 4, 2009 | 10:42 AM
engle1147's Avatar
engle1147
My situation is that my tc does not lock up until 48mph in 4th. .... however once I hit 48 and the tc locks up the temp will hold (at what ever temp is was at that point) and not rise any further and infact over enough time it will fall to within 10-15 degrees (f) of the water temp.
48mph in 4th. This is exactly how my tranny acts - it stays "locked up" until I hit the throttle hard again (goosin' it) or hit the brakes.
'89:
PCM4less chip mod, ~3,000 stall ( http://www.kmjent.com/cart/product.p...3&cat=0&page=1 ) an additional trans cooler ( http://www.summitracing.com/parts/SU...A/?image=large ) in place, insulated ( http://www.summitracing.com/parts/DEI-010408/) oil return line ....my tranny return oil rarely hits 200 F
The above combo works pretty good IMO
Old Dec 23, 2010 | 09:18 AM
Aardwolf's Avatar
Aardwolf
Just to add to this, I went with a non-lockup trans for this last rebuild. I have run it for hours and hours unlocked without any heat issues. Typical temp is 150° with a Derale pan, and B&M cooler.
