Cruise control issues
Old Sep 5, 2009 | 09:57 PM
Kelster's Avatar
Kelster
Cruising
Default Cruise control issues
Was driving along in my '85 with the cruise control on. The car just started to accelerate. Nothing on the gas, nothing pushing against the accelarater & feet away from the same.
I am a new Vette owner. Never had any other type of care do this. Any one had the same experience, and ideas?
Old Sep 5, 2009 | 10:44 PM
tblt44's Avatar
tblt44
Never tried my cruise,only had my car 3 weeks
Old Sep 6, 2009 | 07:57 AM
2UHONEY's Avatar
2UHONEY
Your cruise will accelerate and decelerate your engine but the speedometer should not move up nor down from what's set on.
Old Sep 6, 2009 | 08:12 AM
Kelster's Avatar
Kelster
Cruising
Thanks for the response. I know that the cruise will accelerate & decelerate the car as required. But mine was set at 100kmh, it will start to accelerate & the speedo increase. I tried it a few times with the same result. Yesterday it went as high as 130kmh, I was seeing if it was just as you said, before I shut it off.
Old Sep 6, 2009 | 08:24 AM
93_vette's Avatar
93_vette
Check the vacuum hoses to the cruise control, they could be sucking air.
Old Sep 6, 2009 | 08:56 AM
Kelster's Avatar
Kelster
Cruising
Thanks. Not that savvy with this stuff. Where would that be? Lol. I do have a haynes manual, I will try looking it up there as well.
Old Sep 6, 2009 | 10:05 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/dankai/Cruise%20Control%209C.pdf
http://members.shaw.ca/dankai/Cruise%20Control.pdf
Old Sep 6, 2009 | 10:46 AM
Kelster's Avatar
Kelster
Cruising
Ok followed the info in the PDF file, TY very much by the way, very helpful. As far as I can see all the hoses are connected, seem in good shape. I did find the boot over the cable a little worn on the bottom of it and the actual unit under the hood a little loose to its mount. Outside of that, any other Ideas? Like I said. You can drive with the cruise on and no issues, then all of a sudden it just starts to accelerate. Not fast, gradual. Just as if you where setting or resuming the cruise. Accelerates about 1kmh a second when it does that.
Old Sep 7, 2009 | 01:19 AM
Pwnage1337's Avatar
Pwnage1337
Mine was doing this today too. Had the cruise set at 70 mph, all of a sudden the car picked up speed like I was running from the cops. Before I knew it I was going 80 mph.
I'm going to check vacuum lines tomorrow too..
Old Sep 29, 2009 | 07:27 AM
RAW1's Avatar
RAW1
This sounds like the same problem that I have with my '94. Vacuum lines seem to be OK. Wouldn't you expect deceleration if there was a vacuum leak? I guess that I am thinking that the "accelerate" servo is sticking in the on position - but I do not know how to verify.
Old Sep 29, 2009 | 07:48 AM
floridamale's Avatar
floridamale
Loss of vacuum should cause the cruise control to lose speed and disconnect.
To Cruise control issues
